passenger side half shaft dana 30! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 12th, 2009, 01:46 AM   #1
AZTEC
AZTEC's Avatar
Default passenger side half shaft dana 30!
i need a half shaft for the passenger side of a Dana 30 for my 99 cherokee. i need the side that connects to the hub more than the one the one that goes into the axle. it was bent slightly one one side of the yoke when it was pressed. i need it asap.
thanks.
AZTEC is offline   Reply With Quote
Old November 12th, 2009, 02:21 AM   #2
kj kyle
kj kyle's Avatar
STUB SHAFT DAMN IT!
j/k
kj kyle is offline   Reply With Quote
Old November 12th, 2009, 03:25 AM   #3
boggin-machine
boggin-machine's Avatar
if you do not know already do not drive or move the jeep with out the stub shaft in the bearing and torqued down. other wise the wheel bearing will fall apart and you will need to replace that. the wheel bearing is just press fitted togather and the pre load of the stub shaft and nut keep it hold it all togather.
Old November 12th, 2009, 03:28 AM   #4
NSmist
NSmist's Avatar
Send a message via AIM to NSmist
Relax boggin, it's sitting on stands in his garage. He has all the parts, but is looking for the stub shaft. See thread
Mazza u joint press - Great Lakes 4x4. The largest offroad forum in the Midwest
(not much different than this thread).
NSmist is offline   Reply With Quote
Old November 12th, 2009, 03:30 AM   #5
boggin-machine
im just stating cause ive heard of it happening more then once when someone doesnt know. being that he is fairly new i through it out there so it doesnt happen.
Old November 12th, 2009, 03:39 AM   #6
kj kyle
kj kyle's Avatar
dont XJs use unit bearings?
Old November 12th, 2009, 07:23 AM   #7
PavementPounder
PavementPounder's Avatar
Yes. Unit bearings cannot hold themselves together under the weight of the vehicle without the stub shaft.
Aztec, I have the passenger inner. Does your XJ have ABS? It makes a difference for the stub shaft. If it is ABS, I have that also.
Old November 12th, 2009, 09:37 AM   #8
jeepers48
jeepers48's Avatar
I have one if this is what your looking for.
94 XJ D30 axle shaft - Great Lakes 4x4. The largest offroad forum in the Midwest
jeepers48 is offline   Reply With Quote
Page generated in 0.21778 seconds with 48 queries
