2003 durango - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 8th, 2009, 06:54 PM   #1
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
Default 2003 durango
sounds like the mil has a front drivers wheel bearing going bad. Sounds like a caliper grind we you turn the steering wheel one direction but the other way no noise.
Bell tire quoted over 500 for the part and labor. They said the part had something to do with the abs which from my research and knowledge I dont beleive this is correct.
From what I can tell all it takes is:
remove tire
remove caliper/rotor
remove spindle nut and cotter pin then bolts on rear of knuckle holding sealed hub
remove hub with chisel
reinstall.
Am i missing any thing. The hub is about 100-110
Silver Bullet is offline   Reply With Quote
Old November 8th, 2009, 06:58 PM   #2
firehawk
Live Action!
firehawk's Avatar
Might need to pull the abs sensor and the odds of getting it out without breaking it are not good.
Old November 8th, 2009, 06:58 PM   #3
boggin-machine
boggin-machine's Avatar
on most of the unit bearings the abs sensor is in it. but you have the gist of it.
Old November 8th, 2009, 07:00 PM   #4
creeping death
I'm that guy.
creeping death's Avatar
you got it!
i just did my pass. side a few months ago on my 2000 durango.
and you do it just as you decribed and it's around $100.
took about an hour start to finish and that's including a parts run.
Old November 8th, 2009, 07:01 PM   #5
Silver Bullet
Does anyone have the chiltons instructions for this? From what i can find nothing mentions the abs sensor.
Old November 8th, 2009, 07:03 PM   #6
Silver Bullet
Originally Posted by creeping death View Post
you got it!
How was it getting "access" to the 2 bolts on the back side of the knuckle?
I heard it is a biatch. Any issues with abs sensor?
Old November 8th, 2009, 07:06 PM   #7
MusKegon_ZJ_gurl
Extraordinarily Ordinary
MusKegon_ZJ_gurl's Avatar
All the manuals you will ever need are right here.
You just need to use your MI Drivers license number to log in.
Free usage of Chiltons online manuals - Great Lakes 4x4. The largest offroad forum in the Midwest
http://www.glfwda.org/
MusKegon_ZJ_gurl is online now   Reply With Quote
Old November 8th, 2009, 07:06 PM   #8
boggin-machine
most have atleast 3 bolts
Old November 8th, 2009, 07:18 PM   #9
creeping death
I'm that guy.
it has 3 bolts. a bit tight in the back but not too bad.
not all of them have front abs.
if yours does the part will be quite a bit more expensive.
if you are not sure if yours does and you have other wheels just pull it apart. you'll know.
Old November 8th, 2009, 08:28 PM   #10
badazzamc
Get Some
badazzamc's Avatar
if the steering knuckle is aluminum, good luck, there aluminum on the new rams and they dont like to come out. If its not aluminum, real easy to do
Old November 9th, 2009, 06:07 AM   #11
Silver Bullet
link does not work (like the last post from some supe smart guys says. lol)
Old November 9th, 2009, 06:12 AM   #12
MusKegon_ZJ_gurl
Hmmm
That pretty much just sucks.
Old December 11th, 2009, 07:42 AM   #13
sonic
sonic's Avatar
A lot of times if the sensor is in the hub it will come with a new one in it and you disconnect somewhere along the harness. Yes a lot of times if you do need to reuse it they dont come out with out breaking. You have the idea as far as repair goes. Turning the knuckle allows for more clearance and also remove the axle nut first. Without damaging the threads on the axle shaft push the axle back through the knuckle a bit. This should allow for more room as well. With a little patients these really are not bad to do. Might be helpful to have a torch handy. Sometimes the hub bolts are pretty rusted in there.My guess is that they quoted you that much A: anticipating problems removing the old one
B: They kinda just like to rip people off on things from my experience (quoted me tie rods when I just replaced em and took the truck there for an allignment)
Do it yourself. You can do it.
sonic is offline   Reply With Quote
Page generated in 0.30423 seconds with 63 queries
