Chevy 6.0 piston slap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 8th, 2009, 07:23 PM   #1
ranger98
titties
ranger98's Avatar
Default Chevy 6.0 piston slap
Does anyone know of any way to quite down piston slap on a 2002 chevy 6.0
ranger98 is offline   Reply With Quote
Old November 8th, 2009, 08:17 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
rebuild the engine with a tighter tolerance. otherwise no. it won't harm anything. LS engines run for a very long time and all the 99-02 engines have that common problem and i've seen some 99's with over 250,000 miles already with original engine intact.
Old November 8th, 2009, 09:25 PM   #3
Tom
Because racecar
Tom's Avatar
My 01 LS series engine has piston slap. It has 260,000 miles on it (original motor). I wouldn't worry about it.
Old November 8th, 2009, 09:29 PM   #4
badazzamc
Get Some
badazzamc's Avatar
just drive it
Old November 8th, 2009, 10:33 PM   #5
CHEROKEEMUDMAN01
mellow yellow
CHEROKEEMUDMAN01's Avatar
My 99 And 2002 Had The Same Prob Chevy Told Me The Reason For That Is They Shortened The Bottom Of The Piston Head So It Tends To Bounce Back And Forth. I Never Had Any Issues With Eather Motor So I Would Worry About It Drive It Like U Stole It!
CHEROKEEMUDMAN01 is offline   Reply With Quote
Old November 8th, 2009, 11:34 PM   #6
Disturban
Disturban's Avatar
I know it is a common problem on 6.0's when they are cold but after the motor warms up you should not hear it. If you do still hear it after it warms up I would try a different grade oil. If it calls for a 5w30 try a 5w40, redline and rotella both make a great 5-40, don't change the first number in the oil because that is your cold flow properties, a 10w40 is a lot thicker at startup than a 5w30 however once at operating temp they are both a 30 weight.
Old November 9th, 2009, 07:15 AM   #7
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I don't think a thicker oil is going to help with the pistons rocking in the bores.
@clarkstoncracker
Old November 9th, 2009, 07:22 AM   #8
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
x2, but if I remember right they did have an issue with some cheap oil filters that would let all the oil run back to the pan and cause noise on start up, where the ac delco filter had a valve or something to keep it from doing so, I think???
BAD93SBLZR is offline   Reply With Quote
Old November 9th, 2009, 08:30 AM   #9
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Oil draining back and thin oil causing noises on startup is more about sloppy bearings and collapsed lifters, I think.
Piston slap comes from the piston rocking in the bore from the forces that come from the connection rod acting about the wrist pin. IIRC, they solved the problem in newer engines with a slightly offset pin position in the pistons.
@clarkstoncracker
Old November 9th, 2009, 08:32 AM   #10
kj kyle
kj kyle's Avatar
yea, GM made the piston too small trying to save weight for better fuel milage. or at least thats what i was told.
kj kyle is offline   Reply With Quote
Old November 9th, 2009, 08:33 AM   #11
kj kyle
kj kyle's Avatar
and that sounds like FRAM the anti drain back seal is paper, and deteriorates after a thousand miles..... or so i was told
Old November 9th, 2009, 09:13 AM   #12
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
It was to reduce friction - since then, I believe the skirts are a bit longer and a anti-friction coating has been applied.
@clarkstoncracker
Old November 9th, 2009, 10:30 AM   #13
ranger98
titties
ranger98's Avatar
Hey well thanks guys i appreciate it.. everyone told me it wasnt a big deal but just wanted to make sure.. its kinda annoying
Old November 10th, 2009, 06:31 AM   #14
Disturban
Disturban's Avatar
It will not help with the pistons rocking but it will help quiet it down.
Old November 10th, 2009, 05:37 PM   #15
ranger98
titties
ranger98's Avatar
alrighty i appreciate it
Page generated in 0.42253 seconds with 68 queries
