85 Jeep CJ7 Fiberglas - 10 year project Rock Crawler, Dune Machine & Trail Rig - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 6th, 2009, 09:32 PM   #1
cj7jack
Default 85 Jeep CJ7 Fiberglas - 10 year project Rock Crawler, Dune Machine & Trail Rig
Fiberglas Body from 4 Wheel Drive Hardware
1987 5.7 TBI w/Painless Wiring Engine Harness
Engine rebuilt & balanced w /30 over pistons, mild hi-po cam, upgraded performance chip in computer - estimated 3000 miles since rebuild
Custom Copper Radiator from Fenton Radiator
Advance Adapters Bellhousing, Motor Mounts and Shorty Headers
T-18 4 Speed w/6.3:1 First Gear
Advance Adapter mainshaft and T Case adapter
Clocked Dana 300 w/4:1 Tera-Low Gears
Custom Skidplate
Scout Dana 44 axles w/4:88 gears
Front – Detroit Locker
Rear – Warn 4140 Axle/Hub Conversion w/Spool
Extra set of driveshafts and Front axle shafts
123:1 Crawl Ratio
Springover w/Cherokee Spring Packs (6" longer than stock CJ) - Maxs out RTI ramp
Custom Shackles w/Relocated frame & spring mounting points
Shock Mounts – extended stock, rear relocated
Custom High Steering - same geometry as stock CJ only relocated above the springs
Wagoneer Drag Link (shortened) and Tie Rod - 1 1/8" diameter (much stronger than stock CJ)
Custom Steering Knuckle Brackets to bolt on to the Scout knuckle casting
Dropped Pitman Arm
Frame stretched 2”
5000# Winch with pulleys, straps & D-links
Custom Bumpers & Swing-out Tire Rack
Bestop removable rear seat - almost new condition
Custom 6 Point Roll Cage w/ racing 3 point shoulder harnesses front & back
Custom Rock Rails
Unfinished On-Board Air - have all components
Custom Beadlocks – 12”rims 38.5x15x16 Swampers - run 3 to 4 lbs on rock - incredible traction with about the same clearance as fully inflated 35"s
Custom towbar and coupling for flat towing
Extra set tires and wheels 15x10 alum rims with 35x15.5x15 TSL - SX's
Lots of other xtra stuff
Best Offer or will consider small car in good condition such as a Saturn plus cash$$
pm or e-mail me for more info or more pictures
Picture is at Windrock Offroad Park in Tennessee on the Rattlerock trail.
Last edited by cj7jack; May 15th, 2011 at 11:24 PM. Reason: Price reduced - Gotta sell soon!
cj7jack is offline   Reply With Quote
Old December 8th, 2009, 07:50 PM   #2
cj7jack
Default Beadlocks provide awesome traction!
Still available - it's a deal!
Old December 8th, 2009, 08:55 PM   #3
LILL ZJ
LILL ZJ's Avatar
http://www.greatlakes4x4.com/attachm...&d=12603272777
How much would you knock off your price for this? Toyota celica 210,000 runs great, no rust , manual
ID:	53972   Click image for larger version
LILL ZJ is offline   Reply With Quote
Old December 8th, 2009, 10:08 PM   #4
scare-crow
the eskimo bro
scare-crow's Avatar
Send a message via AIM to scare-crow
why are u selling off ur toys jack?
scare-crow is offline   Reply With Quote
Old April 5th, 2010, 01:13 PM   #5
cj7jack
No job - need money
Old April 25th, 2010, 11:42 AM   #6
scare-crow
the eskimo bro
scare-crow's Avatar
bump
Old August 26th, 2010, 09:53 AM   #7
cj7jack
Default Still available
sweet runner - idles over anything!
Old October 17th, 2010, 09:12 PM   #8
Gracy
Is this jeep still available ?
Gracy is offline   Reply With Quote
Old December 10th, 2010, 01:45 PM   #9
reddoggdgp
reddoggdgp's Avatar
Your CJ still available?
reddoggdgp is offline   Reply With Quote
Old May 15th, 2011, 11:55 PM   #10
cj7jack
Default Still Available
Yes the CJ is still available. It is primarily a trail/rock crawler. My Boys are gone and I just don't use it any more. It's time for it to go.
Call me!
Jack 810-287-8143
Old May 16th, 2011, 09:29 AM   #11
andrew.c 02
how much
andrew.c 02 is offline   Reply With Quote
Old June 5th, 2011, 08:57 PM   #12
cj7jack
$6500
Call me if you are serious,
Thanks!
God Bless You!
Jack
810-287-8143
Old June 7th, 2011, 06:27 PM   #13
1999WJ_V8_Limited
Rollin'
1999WJ_V8_Limited's Avatar
Do you happen to be looking for any trades? PM me
1999WJ_V8_Limited is offline   Reply With Quote
Old June 17th, 2011, 01:30 PM   #14
1999WJ_V8_Limited
Rollin'
ttt sweet CJ
Old June 17th, 2011, 02:40 PM   #15
manny1983
Interested in a trade?
gmc k2500 turbo diesel - Great Lakes 4x4. The largest offroad forum in the Midwest
manny1983 is offline   Reply With Quote
Old June 19th, 2011, 02:14 PM   #16
cj7jack
Yes, I am interested in a trade. I need a reliable small car to drive to work. What do you have in mind?
Page generated in 0.37808 seconds with 73 queries
