granny four speed clutch setup? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 4th, 2009, 03:14 PM   #1
wobbles
wobbles's Avatar
Default granny four speed clutch setup?
Hello I'm new to the forums and somewhat new to the 4x4 world. I got an 83 chevy k10 with a 350 and soon to be sm465 trans. I am converting an auto into a stick and i dont know how the clutch is setup. is it a hydrualic setup or a mechanical setup? or is it possible to do either or?
Thanks in advance
wobbles is offline   Reply With Quote
Old November 4th, 2009, 03:31 PM   #2
kj kyle
kj kyle's Avatar
my driveline is out of an 80s k10 and it is hydro.
350 / sm465 / np 205.
kj kyle is offline   Reply With Quote
Old November 4th, 2009, 05:58 PM   #3
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
87 and up they used hydraulic 86 and down they used mechanical. yes you can convert it all you will need is the pedal assembly out of a donor vehicle and the linkage rods. if you already have the trans and bellhousing you will obviously need a flywheel and clutch assembly to fit your engine as well
Old November 4th, 2009, 06:16 PM   #4
deerebowtie
Unchained
deerebowtie's Avatar
i just got through with the same swap for about 250$ (manual linkage). a hydraulic setup would be ideal due to the horrible frame flex these trucks have without doing any frame bracing, but it costs more. If you need a complete parts list for a manual setup, shoot me a pm.
Old November 4th, 2009, 06:42 PM   #5
wobbles
wobbles's Avatar
thanks for all the info.
well the plan is to box the frame so after that is done would a mechanical setup be a cheaper way to go or is there still gonna be enough frame flex to make it worth buying a hydraulic setup?
Old November 4th, 2009, 07:03 PM   #6
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
get a mechanical setup. hydraulics are always a pain in the ass to setup and when they go bad they cost a bunch of money to fix
Old November 4th, 2009, 07:22 PM   #7
deerebowtie
Unchained
after boxing the frame you're good to go with a mechanical setup. next question, is your cab a low hump or high hump floor?
Old November 5th, 2009, 10:26 AM   #8
wobbles
wobbles's Avatar
well it is an automatic cab so probably low hump.
Old November 5th, 2009, 10:47 AM   #9
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
lucky for you the hump bolts in. you can add a high humped one if needed. I did the swap on my `72 and didn't need to. just had to cut the hole for the shift tower and added a lower boot as well as an upper to keep the water and crap out.
Yetti
Page generated in 0.23479 seconds with 50 queries
