home built TJ front upper and lower control arms **SOLD** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 3rd, 2009, 05:27 PM   #1
XJeeper
misfit
XJeeper's Avatar
Default home built TJ front upper and lower control arms **SOLD**
Made a set of tj upper and lowers from cut down JK factory control arms. The arms are 1.5" longer than stock to push the front axle forward a bit but not far enough to interfere with steering or track bar geometry. I ran them with 3" bds springs in the front (also available) and had great results. All bushings are in good shape, they have only been on the jeep for 8 months. $100
Justin
these have been sold.
ID:	52394   Click image for larger version
ID:	52395   Click image for larger version
ID:	52396   Click image for larger version
XJeeper is offline
Old November 3rd, 2009, 09:05 PM   #2
srlbotanical
Because I Said So...
srlbotanical's Avatar
pics?
srlbotanical is offline
Old November 4th, 2009, 07:10 AM   #3
XJeeper
misfit
XJeeper's Avatar
dont have any at the moment. Ill see if I can get the shop kid to snap a couple today.
XJeeper is offline
Old November 10th, 2009, 07:07 AM   #4
XJeeper
misfit
XJeeper's Avatar
pics should be added today.
XJeeper is offline
Old November 10th, 2009, 07:46 AM   #5
XJeeper
misfit
XJeeper's Avatar
pics! added!
XJeeper is offline
Old November 10th, 2009, 08:02 AM   #6
MTUCJ7
Never Wheeled Before
MTUCJ7's Avatar
Are these only the fronts? or f/r?
MTUCJ7 is offline
Old November 10th, 2009, 10:45 AM   #7
XJeeper
misfit
XJeeper's Avatar
just fronts, upper and lower.
XJeeper is offline
Old November 10th, 2009, 06:22 PM   #8
BLUE 01
member
How would thes work on an xj with 3 inchs of lift, would they be to long?
BLUE 01 is offline
Old November 11th, 2009, 05:01 PM   #9
Trailrig
Hoggin'-N-Boggin'
Trailrig's Avatar
Send a message via AIM to Trailrig
how much concrete did you fill them with?
Trailrig is offline
Old November 12th, 2009, 07:16 AM   #10
XJeeper
misfit
XJeeper's Avatar
not funny.
THERE ISN'T ANY CONCRETE IN THESE!
BLUE '01, Yes, they will work for a Cherokee with 3" lift. It is essentially the exact same front suspension as a TJ and 3" of lift is what I was running.
XJeeper is offline
Page generated in 0.28227 seconds with 54 queries
