1966 Chevrolet C-10 (TourMater) - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 6th, 2009, 01:14 AM   #41
jeeperbrian
GLFWDA member
i wanted to buy this truck
sweet ride ScOoTeR
Old November 15th, 2009, 07:29 PM   #42
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Default LOL...hosed.
Looks like I will be picking up a 383 stroker motor this weekend.
A coworker has a vintage aluminum intake - but it's single plane, so not sure I'll go with that.
Well, today I started to tear down the engine I bought - these are the specs that were listed:
The motor is a 377-CID stroker combination :
- 350 block STD bore and a 400 crank machined to fit the 350 journals.
- 5.565" rods and STD 350 pistons
- 4 bolt main block with fresh cylinder hone
- Hydraulic flat tappet cam, 224 Int/ 234 Exh @ 0.050" lift
- All new bearings and gaskets.
- Heads are GM 882 casting with mild port and polish job,76cc. 9.5:1 compression, with 2.02/1.60 valves
- Intake is gasket matched to the heads
- Engine is painted blue
- Intake is powder coated oxide red
I'm much more versed in rebuilding motorcycle engines, but I don't think a few things are right...
These "new bearings" sure look funny...
Must have used a different gasket to do the matching...
I got cheated on my dial gauge! Clearly, I have 2.02" intake valves, but my calipers must be off...
Something for no extra charge!
These must be for improved oiling:
Sigh. What a fucking mess. "Fresh hone" must mean knocking down the ridge until you go through a set of stones.
I bought this engine from someone that bought it from someone else that traded something for it in the beginning - so, I'm not about to go trying to get my money back. Looks like I'll have a bit more work to do.
I haven't plastiguaged the mains yet - just the four of the rods... and they are from 0.007 to 0.03. (that's NOT a typo). I hope to hell the mains are in spec and I can get away with having the crank cleaned up and the rods resized - though who knows what else is hosed with this damn thing.
@clarkstoncracker
Old November 15th, 2009, 08:29 PM   #43
Fraser
Fraser's Avatar
Holy crap, thats no good
Old November 15th, 2009, 08:53 PM   #44
cornfed
I have an avatar. Yippee.
cornfed's Avatar
Probably everything else. Sorry 'bout the luck.
Old November 16th, 2009, 01:00 AM   #45
kargod
Charcoal Mellowed
kargod's Avatar
The f-ed up motor you bought will end up being better than they had claimed in the end - and you know the work is done to your standards when you did it yourself.
The only way I would buy any performance motor is if it was apart when I went to look at it.
Think about how many of that 95% of this website that you quoted before have built motors...
kargod is offline   Reply With Quote
Old November 16th, 2009, 08:41 AM   #46
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
That's what I get for trusting someone with good i-trader . It's totally my fault though - and you are 100% about me not taking the time to inspect it before the purchase.
In defense of the person I purchased it from - I think he bought it (like I did) not knowing about the external balancing issue - maybe when he found out about having to have it balanced, he just didn't have the time or inclination to do it.
You're also correct that it will be done right when I do it - but this seriously changes plans this winter - because I don't have the funds allotted for a for build on an engine (because everything will be gone through completely).
Looks like the 283 will get a refresh over the winter - at least new gaskets, seals, rings and timing chain (and a valve job).
@clarkstoncracker
Old November 16th, 2009, 12:03 PM   #47
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Well, well, well...
I found the original builder of the engine...
http://www.greatlakes4x4.com/showthr...&highlight=377
Originally Posted by Brads01ws6
the block and heads came from a camaro block was cleaned and honed, heads were checked and ported, crank was cut to 350 journals, and machined to clear the pistons, rods are also reconditioned 400 rods cut to 350 journal, motor has not been fired since it assembly. was gonna use it for firgure 8 racing in a 76 monte carlo but dont know if ill have the money to build the rest of the car so putting the whole project on hold until the money situation gets a little better.
I would seriously reconsider EVER buying something from Brads01ws6
Since SBC's come from anywhere and go anywhere, the camaro part isn't misleading, however,
* the block is from a 1970 C10 (according to the stamping)
* the heads are these:
1970-80 333882 350,400 1.94 1.5 76
E164 = Cast on May 16th, 1974
The crank is a 400 casting...however - I'm not sure on it never being fired...
So I found the root of my engine problem. Brads01ws6.
I can't do anything about it, however, I can let people know that anything you sell may not be 100% factual.
@clarkstoncracker
Old November 16th, 2009, 01:00 PM   #48
cornfed
cornfed's Avatar
That's shitty.
If you want to totally change directions, I'll have a 2WD 7.3L PSD van turbo drivetrain and E450 rolling chassis on the market, soon. Or, I know of the whereabouts of a very affordable 6.0L LQ4.
Old November 16th, 2009, 01:03 PM   #49
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I was going to go with a modern GM engine to begin with, but my wife wanted a carbed v8.
Check FML to see if my post gets added.
@clarkstoncracker
Old November 16th, 2009, 01:28 PM   #50
deuce228
Redneck Poser
deuce228's Avatar
"Today, I had nothing better to do than make a penis out of silly putty. FML"
Old November 16th, 2009, 01:31 PM   #51
crassell
crassell's Avatar
Shit dude $650? I would be pissed.
Dont care who built it i'd be seeking money back from dmc. Doesnt say it needs rebuilt in his add. So hes the current seller. He should have did some research into it before passing it on.
He mis-represented it.
I would never resell something based solely on the PO's word or description.
IDK, just my .02
crassell is offline   Reply With Quote
Old November 16th, 2009, 01:36 PM   #52
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Uh you bend over and spread your butt hole, take a few lovely pictured and PM or e-mail them off...
JcrOffroad
Zoom Zoom!
Old November 16th, 2009, 01:44 PM   #53
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
To make it known I'm ready to fukc over?
@clarkstoncracker
Old November 16th, 2009, 01:44 PM   #54
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
hahahahaha
Close.
@clarkstoncracker
Old November 17th, 2009, 08:11 PM   #55
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
wow thats the work of a garage floor build. i've seen some shotty engine building before but thats just common sense shit.
Old November 17th, 2009, 08:19 PM   #56
curt1656
Praise the lowered
curt1656's Avatar
Don't worry ScOoT, you will know up front when I'm fawkin you over.
Old November 18th, 2009, 08:14 AM   #57
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Actually, I think it is just the work of a very dishonest seller that misrepresented it to one person, then it got passed on to the next guy, and I bought it to actually use.
@clarkstoncracker
Old November 18th, 2009, 08:28 AM   #58
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
IDK, just my .02
I wouldn't pin it on DMC, I have done business with him myself, and he is a stand up guy. IMO Scooter is handling this properly. He owned up to his end, and dug down to the root of the problem.
Scooter good luck with the build. IIRC machine work on my SBC was around $600 a couple years ago from Reichert Racing. I didn't specify and they built it a little loose though, I think I would run a little tighter tolerances if I did it again.
Old November 18th, 2009, 08:33 AM   #59
Nuggets
I fix stuff!
Nuggets's Avatar
Dood, I love the 60's body style chebys (up to 66). I've owned several of them over the years and they've all been 6 poppers with a three on da tree. Nice smooth driving old trucks.
Old November 18th, 2009, 02:49 PM   #60
danimal
IS IT JEEPIN TIME
danimal's Avatar
I LIKE IT
If you loose interest in it let me know
If your interested I have a 283 (dissasembled for inspection) I have been thinking of selling needs a few things but some machine work was done already ; bored .040 but not finish honed , line bore and deck checked good, power pack heads with all new seats but seats are not finished,new guides installed but not finished, steel crank from a marine engine checked out good but needs to be turned or polished.
I was going to put larger intake valves and flat top pistons in it but never bought anything
as a side note if you check with LMC or GOLDEN STATE you can get a disc conversion and still keep all the original suspension
danimal is offline   Reply With Quote
Page generated in 0.48202 seconds with 84 queries
