1966 Chevrolet C-10 (TourMater) - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 3rd, 2009, 10:37 AM   #21
Originally Posted by JohnL View Post
Just because people do it all the time does not mean it is a good idea. I have not seen a carb'd ls motor make power identical to fuel injection. My friend was looking at putting a carb on the ls1 in his pick up and all the dyno charts and info he showed me the carb was making in the area of 10-15% less power.
From the dyno plots I had seen recently of a bunch of cams being tested with I believe a victor jr intake, the carb made more HP on every cam than the FI did.
Old November 3rd, 2009, 10:45 AM   #22
greygoose
I'm the dude
greygoose's Avatar
Old November 3rd, 2009, 12:18 PM   #23
4Bangler
Jackstand Wheeler
4Bangler's Avatar
I can't believe I'm going to say this, but screw all that LS crap, go grab a dime-a-dozen 350 block, toss in the crank from the 283 (especially if it's steel) with some 327 rods, flat-tops, balance to the moon with either worked over factory heads or some affordable Dart iron heads, cover your roller rockers with valve cover spacers and those nicely patina'd 283 covers, paint an aluminum intake all scroggy to match, stick the stock air cleaner over a modern 4bbl and get it awn. Small-journal 302, old school style for an old school truck.
I love those trucks lowered, but don't be afraid to hoist the front end up gasser style, throw'n sparks off the back bumper is way cooler when the front end is in the air.
Old November 3rd, 2009, 12:27 PM   #24
JohnL
Go until it breaks.
JohnL's Avatar
Send a message via AIM to JohnL
Originally Posted by greygoose View Post
Wasn't saying it couldn't be done. Just the one's I seen weren't. But you sure showed me.
Good luck with whatever you build it like Skooter. Yours will probably be done before mine because I'm slow. Maybe this will give me some motivation to finish mine.
JohnL is offline   Reply With Quote
Old November 3rd, 2009, 12:44 PM   #25
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Originally Posted by JohnnyJ View Post
If the front end is all twisted, and since you plan on dropping it in front, you might just put a diffrent sub-frame up front that has the modern amenities like larger disc brakes, better front end geometry, and better steering.
plan is to grab the front end components off a 73-87 for the updated brakes and 5-bolt wheel pattern.
Drop spindles in the front, notched frame in the back.
@clarkstoncracker
Old November 3rd, 2009, 12:59 PM   #26
greygoose
I'm the dude
greygoose's Avatar
Sounds like a great project. I can't wait to see some progress pictures.
Old November 3rd, 2009, 12:59 PM   #27
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Put a 22r in it.
JcrOffroad
Zoom Zoom!
Old November 3rd, 2009, 01:07 PM   #28
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
You're preaching to the choir.
If I can't go totally modern, I'm not going to dumb-down a F.I. motor to use a carb. I have access to a small-journal 327 block to stuff my 283 crank and rods into to wind up with the same effect, however, I'd like torque below 4000 rpm too - that's why I'm considering a 377. A few more cubes and similar piston speeds to wring out 6500 rpm (or more )
I will use all the old patina-ed parts I can, with the exception of buying THESE.
I will also look for an old offy or weiand aluminum manifold with the hole for the oil-filler tube to finish it off. I am also working on figuring out a good way to hide programmable spark timing.
@clarkstoncracker
Old November 3rd, 2009, 01:43 PM   #29
roll-bar Bob
roll-bar Bob's Avatar
Originally Posted by Monkeyevil View Post
Put a 22r in it.
x2
Old November 3rd, 2009, 02:00 PM   #30
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Put a 22r in it.
Originally Posted by roll-bar Bob View Post
x2
Stop peeing in my happy water.
@clarkstoncracker
Old November 3rd, 2009, 09:04 PM   #31
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Your wife basically said it reminds her of her fathers car... which probably had some crappy 4 cylinder in it.
Thus 22R.
OH SICK BURN!
All kidding aside, I'd love to have some old iron with a modern jap turbo 4 banger. Oh how it would anger people at car shows *lol*
JcrOffroad
Zoom Zoom!
Old November 3rd, 2009, 09:38 PM   #32
4Bangler
Jackstand Wheeler
4Bangler's Avatar
I've got a vintage cross-ram dual quad intake...but it's not for sale, and I know a guy with a triple v-belt driven 4-71 blower topped with (4) 1bbls....he says he won't sell that either....
Petronics conversion in a vintage Mallory or Accel points distributor body....ooh yeah.
Old November 4th, 2009, 10:28 AM   #33
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
You're no help, Jackass!
I'll find something on the H.A.M.B., I'm sure.
@clarkstoncracker
Old November 5th, 2009, 09:28 AM   #34
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Looks like I will be picking up a 383 stroker motor this weekend.
A coworker has a vintage aluminum intake - but it's single plane, so not sure I'll go with that.
@clarkstoncracker
Old November 5th, 2009, 10:31 AM   #35
insane88yj
insane88yj's Avatar
Easyest way to do up grade is to swap out entire frame from early to mid 80's truck. Easy swap by far possibly swap frame mounts if need be other wise frames are prity close. Or I have seen people mate a 70's camaro front sub into frame and use a 12 bolt car rear end.
Ya it is hard to beat the HP from a carberated motor. But depending on what he is using it for it is eaven harder to beat the dependability of fuel injection. That and no offence but some women don't under stand the full concept of how to start a carberated motor. Due to they ae to used to fuel injected ones.
insane88yj is offline   Reply With Quote
Old November 5th, 2009, 10:38 AM   #36
greygoose
I'm the dude
greygoose's Avatar
How is this bad? Then the woman will never take his truck.
Old November 5th, 2009, 10:48 AM   #37
insane88yj
insane88yj's Avatar
LMFAO
True but I thaught it was for her to drive. O for them to share. LOL
Old November 5th, 2009, 12:16 PM   #38
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Frame will stay 1966.
Front suspension will be sourced from a 73-87 1/2 Chevy.
Rear end will be a 12-bolt similarly sourced and I'll make my own panhard setup for it.
And as far as my wife, she is smarter and better versed in internal combustion engines than 95% of this forum.
She already understands the drawbacks to a carburetor, and that is the reason she wants to keep one.
@clarkstoncracker
Old November 5th, 2009, 12:31 PM   #39
insane88yj
insane88yj's Avatar
good to here. cause some "people I should say short of puting the key in ignition and turning it to start if they have to do any more they are lost.
Old November 5th, 2009, 02:24 PM   #40
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Those people own Toyota Camrys.
@clarkstoncracker
Page generated in 0.37202 seconds with 84 queries
