1966 Chevrolet C-10 (TourMater) - Page 11 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 17th, 2011, 08:56 PM   #201
J Truck Rick
J Truck Rick's Avatar
Great job so far........whatcha gonna do with the old tranny?
J Truck Rick is offline   Reply With Quote
Old January 17th, 2011, 09:14 PM   #202
ssdeuces
ssdeuces's Avatar
plasma....
Scot, you must have a torch there...buy a Henrod 2000...
I like mine...
ssdeuces is offline   Reply With Quote
Old January 18th, 2011, 07:49 AM   #203
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Scrapped - I've seen several SM420's for sale on this site for what I thought were decent prices and no one was buying. I just decided to pitch it to get it out of my way.
@clarkstoncracker
Old January 18th, 2011, 07:50 AM   #204
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Originally Posted by ssdeuces View Post
plasma....
I like mine...
I like what I've seen of the henrob, just can't justify $350 on it right now.
@clarkstoncracker
Old January 19th, 2011, 06:38 PM   #205
J Truck Rick
Ouch! NONE that I saw were within 100 miles of me!I have a rube adapter,to mate one to a type18 t/c & a warn-type over drive.This will go behind a marine buick 225 v6 in 'glass-bodied flatfender,that will give me 16 forward speeds&4 reverse!......No biggie I'll find one.......Oh,I scrapped a'63 GMC short bed chassis with leaf spring rear a couple years back!
Old January 23rd, 2011, 04:46 PM   #206
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Front end fabrication almost done
Comparison of the "chopped" crossmember vs. stock:
Backing plates in, notches cut out and reinforced:
Reinforcement for upper a-arms completed:
Next is to order the drop spindles and front-end crap, along with a mustang II steering rack and get it set up.
@clarkstoncracker
Old January 23rd, 2011, 04:56 PM   #207
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Nice work, Scot.
Old January 24th, 2011, 01:03 PM   #208
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Well,
Just ordered:
T-bird turbo coupe steering rack (quick ratio)
all balljoints and a-arm pivots
TREs
CPP 2.5" drop spindles
stock height springs
HD 5x5" brake rotors
While I wait for all that shit to filter in, I still need to find some 5x5" rollers, rip out the stock rear end and start to figure out how the g-darned IRS is going to fit back there.
@clarkstoncracker
Old January 24th, 2011, 01:07 PM   #209
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
This is gonna be sweet when you get it done, whatever you do don't give up
Old January 24th, 2011, 05:17 PM   #210
95geo
newbie
95geo's Avatar
Looking good!!! You're picking up the fabbing quickly! It is definitely a fun hobby when its enjoyable.
Old January 25th, 2011, 05:46 AM   #211
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Thanks Bryce - I consider that one heck of a compliment!
<edit>
Just spent a small fortune @ Eastwood.
@clarkstoncracker
Old January 31st, 2011, 07:19 AM   #212
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
No pics - but one side of the front suspension is on, the engine & trans is in for mockup and I'm working on the rackmounts.
@clarkstoncracker
Old February 2nd, 2011, 10:09 AM   #213
littletrucker
I'd hit that
littletrucker's Avatar
Do you think the frame is strong enough where you notched it without boxing it?
Old February 2nd, 2011, 12:33 PM   #214
I wonder as well. Might be a good idea for a little plating/boxing.
Old February 2nd, 2011, 01:11 PM   #215
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
It reinforced with 18 inches of 1/4" steel welded to the inner frame rail, then 1/4" notches were welded in.
This is *way* overkill for the location - especially when you compare it to the kits that are sold out there: Some weld in a 1/4 notch to the frame with no other reinforcement, others offer a 6" wide plate that is thru-bolted to the inner frame rail with like 15 bolts.
I did some analysis and the new cross section is about 75&#37; as strong as the unnotched frame. The frame ahead of the notch only has about 700 lbs. of static load - and I'm nowhere near yield (hundreds of psi vs. millions) with the new section. I DO realize this will make a difference in an impact, but it's too complicated to calculate (can't just approximate a cantilevered beam solution for a frontal impact).
I plan on boxing the frame *behind* the front suspension as I have increased the twisting of the frame rails about their own axes by increasing the lever arm by 2".
@clarkstoncracker
Old February 2nd, 2011, 01:22 PM   #216
littletrucker
I'd hit that
I see that in the pictures now
Old February 2nd, 2011, 02:11 PM   #217
We'll call it crumple zones :)
Old February 2nd, 2011, 08:19 PM   #218
crosseyed cat
safety cone killer !!!
crosseyed cat's Avatar
nice job on the crossmember and the frame will be awesome when its done!!!
crosseyed cat is offline   Reply With Quote
Old February 4th, 2011, 06:42 AM   #219
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Quick picture update.
Rack and engine are near their final spots - ended up having to move the engine back an inch and I need to order a smaller crank pulley and damper. The current ones are 8" in diameter and the ones I'm getting are 6". This becomes very important with respect to where the rack wants to be for the steering geometry to work out.
High-dollar spacers to match alignment with the serpentine setup - temporary, of course.
Looking at the blurry spots - you can see where the rack would benefit from more clearance from a smaller damper and pulley.
I got these headers for like $5, and with the current mounting location of the engine (and ditching the mechanical clutch linkage) - these fit and will be used. Once I cut off the air injection tubing, there is plenty of room to run the steering shaft to the rack input (blurry silver spot in the photo)
@clarkstoncracker
Old February 4th, 2011, 07:10 AM   #220
cornfed
I have an avatar. Yippee.
cornfed's Avatar
I love you, man.
Page generated in 0.94009 seconds with 84 queries
