1966 Chevrolet C-10 (TourMater) - Page 10 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 14th, 2010, 07:15 AM   #181
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Okay, full custom frame idea has been jettisoned in favor of a "new" 1964 rolling chassis I found.
Here's the donor:
@clarkstoncracker
Old December 14th, 2010, 07:19 AM   #182
s.hembree
s.hembree's Avatar
You gonna keep the mud flaps? They're sexy!
Old December 16th, 2010, 05:44 PM   #183
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Default Barbie Queue!
Fuck yeah!
Rotisserie's done!
@clarkstoncracker
Old December 16th, 2010, 05:47 PM   #184
bigbchevy
missmrgreenagain
bigbchevy's Avatar
looking good!
H.o.r.e
Old December 16th, 2010, 06:10 PM   #185
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Is the rotisserie 2 harbor freight engine hoists?
JohnnyJ is online now   Reply With Quote
Old December 16th, 2010, 07:08 PM   #186
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Fuck yeah!
Rotisserie's done!
Close-up pics of attachment points, please.
Old December 16th, 2010, 07:27 PM   #187
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
You betcha.
@clarkstoncracker
Old December 16th, 2010, 07:41 PM   #188
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Rear. The "tabs" have bolts through them and into the rear cab mounts:
Front. The cab has support rails that run the length of it and terminate at these spots - it is also the main structural connection for the inner fenders.
Another front shot -
After I get some other things taken care of, the stands are coming apart and getting modified a bit. They'll be widened and get casters, the centers will get bolted together instead of clamped, AND, the pivot housing is getting a clamp built in to it - I don't like using "pins" to secure my cab from rotating.
@clarkstoncracker
Old December 16th, 2010, 07:47 PM   #189
1x1_Speed_Craig
Simplify...
Nice, and creative. Does it have enough height to clear when it's rolled around, or does it just allow you to angle it 45-degree-ish each way?
Craig
Old December 16th, 2010, 08:06 PM   #190
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Craig
Thanks! About ninety bucks worth of creativity!
Um, I'm not going to see just how far it goes without a spotter.
I'm hoping for 65-70 deg of rotation - but not till I add a bit more stability.
@clarkstoncracker
Old January 7th, 2011, 06:13 AM   #191
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Default update
Got the new chassis...
Set up at the final ride height to measure for suspension components:
Cut 2" out of the front crossmember for ~ 1/2 of the drop on the front suspension:
Plan is to go with drop spindles for another 2.5" lower up front. This route, I can keep decent geometry - which shorter springs don't let you do. Planning on getting the front crossmember done tomorrow - then start mocking up the new engine and trans location.
@clarkstoncracker
Old January 7th, 2011, 06:39 AM   #192
kixx007
Certified Ypsilantian
kixx007's Avatar
New bed yet?
kixx007 is offline   Reply With Quote
Old January 7th, 2011, 07:08 AM   #193
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
New line yet?
@clarkstoncracker
Old January 7th, 2011, 07:25 AM   #194
kixx007
kixx007's Avatar
Yes, but not for you.
Old January 13th, 2011, 10:28 AM   #195
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Default Crappy cellphone pics
2" chop of the crossmember - just a bit more filling and grinding to go.
@clarkstoncracker
Old January 13th, 2011, 10:42 AM   #196
bigbchevy
missmrgreenagain
bigbchevy's Avatar
sweet ride!
H.o.r.e
Old January 16th, 2011, 10:00 AM   #197
curt1656
Praise the lowered
curt1656's Avatar
Shiny!
Old January 17th, 2011, 04:43 PM   #198
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Update:
Things have been a bit slow on the truck, as I got Fallout # for Christmas and have been busy shooting bad guise.
So, here are a few pictures:
Old & Busted:
New Hottness:
Notches cut for R&P steering & inner fish plates roughed out. These plates will be the base to tie in the top and bottom of the frame's cross-section. This is necessary because of the notches AND the added moment arm the upper A-arm will have since it is mounted higher.
All I know is this: I want a plasma cutter so bad I can taste it.
Other developments:
I am now the proud owner of a Ford 8.8 IRS out of a T-bird supercoupe; stay tuned...
@clarkstoncracker
Old January 17th, 2011, 06:11 PM   #199
curt1656
Praise the lowered
curt1656's Avatar
Did you get the matching front axle from the Ford 8.8 IRS?
(lookin good)
Old January 17th, 2011, 07:30 PM   #200
cornfed
I have an avatar. Yippee.
cornfed's Avatar
Update:
You suck at personal time management. Hire 'wooha for a consultation immediately.
Fag.
Page generated in 0.44149 seconds with 84 queries
