1994 XJ D44/AMC20 Hidden 3 Link 36's *SOLD* - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 1st, 2009, 05:51 PM   #1
xj_man_646
Wheeler-less
xj_man_646's Avatar
Send a message via AIM to xj_man_646
Default 1994 XJ D44/AMC20 Hidden 3 Link 36's *SOLD*
Up for sale is my 1994 Jeep XJ. I bought it Fall of 2007 and started building it up.
Drivetrain:
~185k miles
4.0L
AX-15
231
36" TSL's on 15"x8" Soft 8's, probably 40% tread. Plenty of life left if a tire groover was taken to them. They are old though, I got them on my first XJ, about 6 years ago.
Front Axle:
1981 Jeep Wagoneer Dana 44
4.10's
Lockrite
Stock diff cover
1.5x.25 DOM steering, 1/2 ton tie rod ends
Rear Axle:
1986 Jeep Cherokee AMC 20
4.10's
Welded diff
Aftermarket diff cover
U-bolt style yoke
Unibody mods:
From the stock LCA mounts back to the spring hanger is plated with 4"x6" rectangle cut in half to form 4"x3" channel. 1" holes drilled for rosette welds, and stitch welding along the top.
From the spring hanger back is plated with 3"x3" angle iron, which also doubles as the mount for the bumper/rear cross member. The bumper itself is 2"x4" rectangle with 2 weld on D-ring tabs. The bumper has been unpainted and the ends have been uncapped since I built it. You can see it here, picture from the trip to the first wheeling trip with the rig after the build
The floors were pretty much 100% replaced. IIRC, 14ga was used, and was bead rolled for strength where it was needed. Since the pics, the entire floor was herculined.
Before:
After:
2"x4" rectangle rockers replaced the stock ones. 4 mounts on each side, each is 1.5"x1.5" square tubing going from the rockers to the unibody rails. There is still a gap between where I cut out rust on the upper rockers to the rockers themselves. I never got around to filling that gap with sheet metal to attach the rockers to the door sills themselves. You can kinda see them in the pic
Front suspension:
XJ 4.5" lift springs
Custom built hidden 3 link + panhard front suspension. Lower links are 2.25"x.375" DOM, upper link and panhard bar are 1.5"x.250" DOM.
2.5" Currie Johnny Joints on the lower links, both ends
3/4" shank, 5/8" bolt heims on the upper link and panhard bar
Link/transmission cross member built out of 2"x6" rectangle. Lower link brackets made from 3"x3" square, upper link/panhard brackets made from 2"x6" rectangle. Custom transmission mount incorporated using a bushing.
Shocks are the standard issue shocks that come with XJ lifts. I believe the ones on the Jeep currently are Ranchos.
Full bump:
Rear suspension:
4.5" XJ lift springs with, IIRC, the 3rd leaf removed. The shackles were replaced with slider boxes. Same as these:
When I was assembling them, I welded them crooked by mistake so they bind. I have another set that will be included, just need to be assembled and put on the rig. When working properly, they work very very well.
Body:
This is the part of this deal that sucks a little bit. The body on this XJ is pretty much useless. I got into some trees coming off of a bad bounce from a tree root on a hill climb my first time out with the rig. Shot me into the trees, and destroyed the left fender completely. Since then, the body has been dented quite well just about everywhere else. The roof was rusting from the inside which I found out the hard way. I'll let the pics of the body do the explaining.
The start of the body damage:
See what I meant with the roof?
Here you can see the bumper and slider boxes. Also one of my favorite pics from wheeling. The unibody rails and sliders were painted in primer red, they aren't rusty.
What it needs:
The Jeep NEEDS a cage. I was going to build it myself this winter, but am now selling the rig. I LOVE wheeling with no doors, but without doors on an XJ, a cage should almost be required.
The front axle needs some work. I WILL have the Jeep home at Thanksgiving break to fix it. The driveshaft has about 1/16" of play at the pinion in all directions, so the outer pinion bearing is probably shot.
What it needs to be 'done' (never got around to it):
Cage
Cap/paint rear bumper
Fill the gap between rockers and body
Slider boxes for the rear suspension, or go back to shackles
Rear shocks - never got any that were the correct length after raising the axle shock mount up from stock.
Front shocks - the shock mounts I have on there right now are single shear brackets built off of the top of the LCA bracket. I have broken the driver's side one twice. I was planning to buy longer shocks and mount them lower down on the bracket and make them double shear. Also, I have the brackets that converts the gay stud upper shock mount to the standard bushing and bolt style.
Front bumper - right now I have two d-ring mounts coming off the front, with a simple piece of square tube welded between.
Cover the upper link - just a hole in the floor for upper link clearance
That's about it really, this Jeep does not need much. I have wheeled this Jeep quite hard, and put quite a few miles on it out on the trail and it is extremely capable and dependable. I have only broken one thing, and that was a front axle shaft due to spitting a u-joint cap. This Jeep was built with only the best techniques that money could allow. I tried quite hard to not cut corners or do anything half-assed, and only friends who are very knowledgeable with fabrication helped me build it. You will not find anything built 'jank' on this Jeep, it just doesn't look very pretty due to the body. This is a VERY mechanically sound Jeep, and WILL take you places.
Spare parts:
Front hubs, bearings, spindles, lockouts, shafts, one rear axle shaft, and probably a bunch of other stuff that I can not think of at the moment.
Starting out at $4000, very negotiable. Bring on the questions, comments, offers, or whatever. I am trying to get into Rally racing with a friend and am selling off my wheeling stuff for funds.
Right now, I do not have my copy of the title. I sent it in after I bought it, and I have not gotten it yet. Maybe it got sent home, but I don't know for sure. I have to call the WI DOT to figure out where my title went, but it is in my name (sent the paper work in, just got no title back).
Jeep is currently located in South Range, MI and will be in Hudson, WI after Thanksgiving
xj_man_646 is offline
Old November 2nd, 2009, 06:21 AM   #2
xj_man_646
Wheeler-less
xj_man_646's Avatar
I also have 1 tons, a Ford T-18 transmission (ready to bolt into your Jeep), 231/300 doubler, bead locks, and a HD diff cover for sale.
Old November 2nd, 2009, 10:55 AM   #3
ddeadserious
ddeadserious's Avatar
Under "Things to be done", it says slider boxes or go back to shackles. Is there something wrong with the current setup?
ddeadserious is offline
Old November 2nd, 2009, 11:37 AM   #4
bbaXJ
Yooper In Training
bbaXJ's Avatar
They’re welded a little bit crooked so they have some binding. He’s got a new set on the shelf waiting to go in.
bbaXJ is offline
Old November 2nd, 2009, 02:25 PM   #5
xj_man_646
Wheeler-less
xj_man_646's Avatar
Yup, exactly. The slider boxes were not welded quite square, big goof up by me in a rush to get it done. They do work while flexing, just not as well as they should. Straight vertical travel like driving down the road is where you notice them not working well, the rear rides really stiff. New slider box components are in my possession and will go with the Jeep.
Old November 3rd, 2009, 11:16 AM   #6
xj_man_646
Wheeler-less
xj_man_646's Avatar
bumpety
Old November 3rd, 2009, 12:10 PM   #7
Blue XJ
The Green Machine
Blue XJ's Avatar
Send a message via AIM to Blue XJ
Whats included with the 231/300 doubler and how much for it?
Blue XJ is offline
Old November 3rd, 2009, 12:50 PM   #8
xj_man_646
Wheeler-less
xj_man_646's Avatar
1 tons, transmission, doubler, who knows what else - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 3rd, 2009, 08:08 PM   #9
Tie Dyed
O.G.
Tie Dyed's Avatar
Send a message via AIM to Tie Dyed
Is that Shift's old XJ?
2000 XJ with a 3 inch body lift
Tie Dyed is offline
Old November 4th, 2009, 12:11 PM   #10
xj_man_646
Wheeler-less
xj_man_646's Avatar
Yup.
Old November 8th, 2009, 04:09 PM   #11
xj_man_646
Wheeler-less
xj_man_646's Avatar
end of weekend bump
Old November 13th, 2009, 12:43 PM   #12
xj_man_646
Wheeler-less
xj_man_646's Avatar
Bump. It has rear doors again, but they're white. Thinkin on painting the rig over Thanksgiving break along with doing some work on it. Hopefully going to get to go through the front axle, and do the rear leaf spring sliders.
Taking offers too. Would love to sell it.
Old November 30th, 2009, 12:37 PM   #13
xj_man_646
Wheeler-less
xj_man_646's Avatar
bump
Old December 17th, 2009, 11:59 AM   #14
xj_man_646
Wheeler-less
xj_man_646's Avatar
bump. money talks.
Old March 11th, 2010, 08:12 PM   #15
xj_man_646
Wheeler-less
xj_man_646's Avatar
Bumping. $2500 OBO.
Old March 11th, 2010, 09:32 PM   #16
Zatzke
Who Needs Luck?
Zatzke's Avatar
you included your whole build thread pidgeon!
bump for ya, good luck with the sale
Zatzke is offline
Old March 15th, 2010, 07:54 AM   #17
xj_man_646
Wheeler-less
xj_man_646's Avatar
Well ya know, I figured that I might as well include as much info as I could!
Old March 17th, 2010, 03:18 PM   #18
xj_man_646
Wheeler-less
xj_man_646's Avatar
Bump. Offers?
Old March 17th, 2010, 04:29 PM   #19
ZJeepMI
ZJeepMI's Avatar
Wow, looks like an awesome deal. Maybe if it is for sale in a while I can pick it up, gotta get mine fixed and sold first. Nice job of the build dude
ZJeepMI is offline
Old March 19th, 2010, 07:49 AM   #20
xj_man_646
Wheeler-less
xj_man_646's Avatar
Thanks, it'll probably be around for awhile at this rate
Page generated in 0.60507 seconds with 84 queries
