sterling 10.5 front axle, Now a Build Thread! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 31st, 2009, 10:42 PM   #1
camccardell
tiger blood
camccardell's Avatar
Default sterling 10.5 front axle, Now a Build Thread!
Ok, I have seen a lot of cool custom front axles
a 609
a 14 bolt front (thanks Ian)
and a few others
Since ford sterlings are so friggin cheap, and I have a few and they are damm near bullet proof, I was thinking of making a steering axle for one.
I cannot seem to find a decent d60 for less than $1000, and I have a set of d60 ball joint inner Cs and some SD knuckes. I would rather use the older 97 down knuckes for the ease of the standard bolt pattern, but anyway...
I would like to get some measurements and information.
a pic of a d60 with a tape running across it would be most helpful.
The axleshafts in a d60 and sterling are the same right? 35 spline?
so if I cut the tubes and weld them the same, i could theoretically use the same axleshaft out of the year of the d60 that I was matching up right?
If anyone wants a set of d60 SD outer knuckles or wants to trade, let me know.
I think this will be a fun project for the winter.
Old October 31st, 2009, 10:45 PM   #2
xj4life
xj4life's Avatar
i'm curious to see where this leads. subscribed
Old November 1st, 2009, 12:15 PM   #3
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
x2
RIP FULLSIZE4LIFE
Old November 1st, 2009, 05:48 PM   #4
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Should be the same as building a 14 bolt front, hardest part will most likely be getting seals to work.
PS Just bought a 79 Hp60 for $350 like 45 minutes from you You just need to keep your eye out for them
Old November 1st, 2009, 06:39 PM   #5
camccardell
tiger blood
that is because you are awsome, and I am a plague carrier, lol
I have a sd d60, and this is what I am going to cut the inner c's off of. If is were complete I might not, but it is just a housing and knuckles.
I am unable to find my calipers. Anyone know the outside diameter of a sd d60 and a sterling 10.5 and 10.25 tubes?
Old November 2nd, 2009, 08:17 AM   #6
Jeepaholic
Jeepaholic's Avatar
99-04 hp60 is 3.5"
05-present is 3.75" tubes
Old November 2nd, 2009, 08:53 PM   #7
camccardell
tiger blood
that would make problem with me using the sd d60 inner c's then
Old November 2nd, 2009, 09:26 PM   #8
Jeepaholic
Jeepaholic's Avatar
what's a 10.25? 3 1/8" or 3 1/4"
you could make a sleeve to make up the difference 3.5" .120 tube or whatever works
Old November 5th, 2009, 12:17 AM   #9
Never_Evil
Other than just being unique, why not just keep it simple??? Use what you have. With the time and money you are going to put into making the new axle, you can purchase remanufactured calipers from any parts store, and come out smelling like a rose. If you are concerned about the wheel pattern being metric, you can order a 8 x 6.5 bolt pattern unit bearings and put in a free spin kit.
I know its not my money to spend, just my 2 cents to throw into the pot.
Old November 5th, 2009, 03:37 AM   #10
camccardell
tiger blood
stubs and shafts = $600
Ring, pinion and carrier $300
STD unit bearings $300 a piece
Calipers over $100 a piece
Free spin kit $???
too much damm money
also, I was told the tubs are bent on the d60 housing, but I sure as hell don't see it.
dosen't mean it isn't though.
My goal was to make this thing and the only thing I would have to buy since I have everything else is the axleshafts and some knuckles.
Old November 5th, 2009, 09:11 AM   #11
Jeepaholic
Jeepaholic's Avatar
I am pretty sure you can use the 92-97 ball joint 60 knuckles and parts on the super duty inner c's.
Old November 5th, 2009, 09:29 AM   #12
Liv2mx might still have some 95? Ball joint knuckles still....I bought the shafts, but he might still have the knuckles.
Old November 7th, 2009, 08:10 PM   #13
camccardell
tiger blood
gear question. will there be any problems with the gears? I ask because my friend said that they won't be meshing properly and I would need reverse cut gears.
I don't think so, but I am not a pro at this.
Any insight?
Old November 8th, 2009, 10:09 AM   #14
Jeepaholic
Jeepaholic's Avatar
The gears work fine but since it is a low pinion axle the gears will be running on the "coast" side which makes them weaker. But so does a chevy/dodge front 60 that is why a Hp front is better.
Old November 9th, 2009, 09:52 PM   #15
kkodet
kkodet's Avatar
Nobody has mentioned yet that the 35 splines are not the same. I figured this out when I tried swapping sterling for dana 70 shafts. They are both 1.5 inch 35 spline, but they are cut at a different angle, and will not slide into eachother. The sterling has wide cut steep splines while the 60/70 has narrow cut splines with less of an angle.
Old November 9th, 2009, 10:32 PM   #16
Ggg
No Both FF Sterlings 10.25, 10.5 use 3 1/2 OD axle tubes.
My 1996 D60 has 3 1/8" axle tubes.
2000 SD D60, and D50 have 3 1/2" tubes.
x2 what keithshotrodshop said about spline profile, spline count is only part of the match up.
Ggg is offline   Reply With Quote
Old November 10th, 2009, 08:24 AM   #17
Jeepaholic
Jeepaholic's Avatar
Well he said it didn't look like they would work but that works prefect for the inner c's
Old November 10th, 2009, 10:08 PM   #18
camccardell
tiger blood
so I'm cool on the inner c's and knuckles, just need custom axleshafts.
I wonder if there is a way to weld yokes to the sterling shafts....
I doubt it would be strong enough though...
hmmm
Old November 11th, 2009, 08:58 AM   #19
kkodet
kkodet's Avatar
I know you said you have alot of sterling stuff. But with the outer stuff you have, you could just pick up a Dana 70 center and build a 70 front. That way you will have no shaft issues, and parts will be a little easier to interchange/find. I've got a bunch of 70 pumpkins myself, and will let them go cheap if you are interested.
Old November 11th, 2009, 12:45 PM   #20
camccardell
tiger blood
i'd need tubes and axleshafts too.
I only have sterling axleshafts, and I'm not too sure I could press out the tubes from the sterlings....
thanks though
Page generated in 0.41689 seconds with 83 queries
