will 94 F-250 parts work on a 94 F-150 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 31st, 2009, 08:28 PM   #1
T_MAN
T_MAN's Avatar
Default will 94 F-250 parts work on a 94 F-150
will 91 parts work on a 94? the parts that I am wondering about are front shock tower and rear leaf springs off a 91 that i want to put on a 94 F-150
T_MAN is offline   Reply With Quote
Old October 31st, 2009, 09:29 PM   #2
camccardell
tiger blood
camccardell's Avatar
yes they will, as long as the width of the leaf springs are the same.
if you go from 2.5" to 3" you will have to change the leaf brackets as well.
Old November 1st, 2009, 09:10 AM   #3
T_MAN
T_MAN's Avatar
how about the shock towers? and headlight switch?
Old November 1st, 2009, 09:26 AM   #4
Never_Evil
Shock towers should work, the headlight switch will not. On the 94 check the wire that goes from the fuse box to the headlight switch, if its burnt at all in any places, replace it immediately. Ford put in undersized wires for the headlights in 92-96. Its a pain the the crapper to replace, but its worth it not having your truck go up in flames.
Old November 1st, 2009, 03:23 PM   #5
T_MAN
T_MAN's Avatar
will a 94 F-250 shock tower and leaf springs ok on a 94 F-150
Old November 2nd, 2009, 08:46 AM   #6
fsumotorhead
N8KVB
fsumotorhead's Avatar
the shock tower will not fit unless the F-250 was a 2wd
the 4x4 250s had leaf spring up front with a different shock tower
Page generated in 0.23593 seconds with 41 queries
