4.3 vortec swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 29th, 2009, 10:08 PM   #1
A4X4SPIT
A4X4SPIT's Avatar
Default 4.3 vortec swap
Im swaping a 4.3 into my spitfire it already has a 3.8 buick im wondering if I can swap out the serpintine belt for v belts ?I want to use tha alt & power steering pump I have in the car any idea what engine I might get waterpump pully & crank pully from ?
A4X4SPIT is offline   Reply With Quote
Old October 30th, 2009, 05:22 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
you can take the pulleys from a pre 86 chevy truck. doesn't matter that it has a V8 cuz 4.3 and V8 stuff are the same when it comes to front acessories.
Old November 2nd, 2009, 01:27 PM   #3
A4X4SPIT
A4X4SPIT's Avatar
dosent putting v pullys on make the water pump spin the opposite way?
Old November 2nd, 2009, 04:36 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
well you will need the correct waterpump for the motor.
Old November 2nd, 2009, 06:25 PM   #5
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
If you are rebuilding a 4.3 for it I got one that is 060 over that needs bearings yet vortec heads all cleaned up already. stock roller cam pm me and let me know
Old November 2nd, 2009, 10:23 PM   #6
A4X4SPIT
A4X4SPIT's Avatar
Ive got a running vortec motor, computer and harness from a s-15 jimmy it should bolt up to my trans set up so it looks like the answer about the v belt set up is it will work with v belts if you get a water pump from a v belt small block or 4.3 engine since the serpintine beltspins waterpump the opposite way of a v belt
Old November 3rd, 2009, 06:15 AM   #7
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
yes you need the whole v-belt setup waterpump and all from a smallblock
Page generated in 0.24650 seconds with 44 queries
