6.0L drive by wire issues - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 29th, 2009, 08:22 PM   #1
JohnL
Go until it breaks.
JohnL's Avatar
Send a message via AIM to JohnL
Default 6.0L drive by wire issues
I have a 1970 C10 I am swapping a 6.0L LQ9 motor into and I'm having a issue someone might be able to help me with.
I got it running and moving so I decided to back it into my driveway and see how well it's running with a couple nice smokey burnouts.
A little background info on the motor. I have had it running for about a month now and it is hooked to a 4L60E. The computer has been re-flashed to allow it to run without catalytic converters. Right now it just has open headers which shouldn't affect anything like this.
Okay , now to the problem. After a couple nice times of driving it up and down my drive way and a few burnouts all of a sudden as soon as the tires break loose I lose the drive by wire.
I hooked it up to my ODBII scanner and it had not thrown any codes yet either.
Is that all clear as mud ? Good.
Thanks in advance.
JohnL is offline   Reply With Quote
Old October 29th, 2009, 08:29 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
what did the engine come out of? my guess is either the pcm has traction control, or you have a wiring fault somewhere. when you say you lose DBW what do you mean exactly.
Old October 29th, 2009, 08:38 PM   #3
JohnL
Go until it breaks.
JohnL's Avatar
Drive by wire is instead of having a mechanical or hydraulic throttle control it is all electronically controller.
The engine is out of 2006 GMC Sierra 2500.
It does not have traction control and I was not running it to red line only about 2k rpms.
Old October 29th, 2009, 08:44 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
i know what Drive By Wire is... i'm asking what do you mean when you say you lose the throttle control. will nothing happen at all or does it only have some throttle input. and traction control is different then rev limiter. traction control limits engine power to prevent wheel slip. rev limiter just keeps the engine from over revving. theres a difference.
Old October 29th, 2009, 08:45 PM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
was the donor truck 2 or 4wd?
Old October 29th, 2009, 08:59 PM   #6
JohnL
Go until it breaks.
JohnL's Avatar
I know the difference. lol
When I lose the throttle control I can have the truck up to a couple thousand rpm's and all of the sudden the engine will go down to idle speed and I can floor the pedal and get no response at all.
But , if I shut it off and restart the engine throttle response is back again until I try to drive it.
The donor truck was 2wd.
Old October 29th, 2009, 09:28 PM   #7
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
did you install the body control module from the donor as well? if memory serves correctly the BCM has something to do with how the throttle works. i found something else called a throttle actuator control module. if thats not there or working correctly then you won't get anything to work right.
Old October 30th, 2009, 06:50 PM   #8
JohnL
Go until it breaks.
JohnL's Avatar
I have not heard of the throttle actuator control module. But the bcm is installed.
I have checked the wiring a million times today looking for a crossed or melted wire and could find nothing. It is still not throwing any codes to the obd machine either.
It ran fine again today until the tires got loose. This is driving me insane.
Old October 30th, 2009, 09:32 PM   #9
frdboy
frdboy's Avatar
I would find someone with a Tech 2 and have them pull codes, I would think it has to be storing something.
Old October 31st, 2009, 10:13 AM   #10
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Sounds like rudimentary series 8 torque security (even though there is not a real torque model in your truck).
One question - does this happen when you're trying to do a brake torque? There may be safety interaction there, but I do not know if the V8 of that year is series 5 or series 8 software. Also, you would need a brake pedal wired into the ecu.
I am trying to get a pinout of the older trucks to help another member on here, so I'll let you know what I find with that.
Does your OBDII scanner have any data recording capability? The trans may also be causing a bit of trouble - I know it can in newer SW, but am unsure of what you're running.
I might be able to get a Tech 2, if you can get the truck to Howell some night after work - or perhaps next weekend. PM me if this is an option for you.
BTW, I have never heard of a
not saying it doesn't exist - but the ETC should be driven directly from the ECU.
Also, inspect all of the wiring connections at the pedal and TB; a momentary loss of signal/voltage (maybe caused by a burnout shaking an intermittent poor connection loose) would shut the throttle down for security reasons.
@clarkstoncracker
Old October 31st, 2009, 12:01 PM   #11
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
sorry i don't know how to make the picture bigger
Old October 31st, 2009, 12:02 PM   #12
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
mind posting that in a size that is legible?
@clarkstoncracker
Old October 31st, 2009, 12:04 PM   #13
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
i don't know how to make it bigger sorry
Old October 31st, 2009, 05:59 PM   #14
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
@clarkstoncracker
Old October 31st, 2009, 06:07 PM   #15
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I found these - might be of some help:
http://www.ls1tech.com/forums/7751980-post70.html
@clarkstoncracker
Old October 31st, 2009, 07:05 PM   #16
silverxj
Recovering XJ owner
silverxj's Avatar
maybe whiterhino can shed some light .. if I recall he had some trouble shooting to do when he did his swap.
Old November 1st, 2009, 08:58 PM   #17
JohnL
Go until it breaks.
JohnL's Avatar
Thanks for everyone's help but I solved the problem. I hooked it to my obdII today and threw 2 codes 1 was because I don't have a check engine light hooked up and the second was a tach code.
I rechecked all of my tach wiring and had the wrong wire that was supposed to be running to the tach was not. Rewired it and now everything is working perfectly. Guy on ls1tech said that the wire was telling the tach it was redlining when it was only at like 2000 rpms so the computer would shut off the throttle.
Old November 2nd, 2009, 09:14 AM   #18
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
AWesome!
@clarkstoncracker
Old November 2nd, 2009, 09:15 AM   #19
JohnL
Go until it breaks.
JohnL's Avatar
AWesome!
Thanks alot for your help Scooter.
Old November 2nd, 2009, 09:30 AM   #20
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Very cool. Glad you got it fixed, now show us some pics of the ride. After my 5.3 jeep is done, I might start a simular build to this one.
RIP FULLSIZE4LIFE
Page generated in 0.36034 seconds with 83 queries
