I gotta try this ! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 29th, 2009, 01:03 AM   #1
Mclovin
"The Situation"
Mclovin's Avatar
Default I gotta try this !
make an air compressor out of an engine
Pirate4x4.Com Bulletin Board - View Single Post - "Build" your own air compressor?
seems easy enough pull the exh push rods and lifters get some check valves in place of the spark plugs plumb into air tank..
ive got a 4.3 sitting in the shed and a nice 220v motor in the garage... hmmmm
Old October 29th, 2009, 01:08 AM   #2
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
Just run the exhaust into a storage tank. Then you can just run it on gas like a normal engine.
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old October 29th, 2009, 01:11 AM   #3
boggin-machine
boggin-machine's Avatar
thats to cool
Old October 29th, 2009, 01:12 AM   #4
Mclovin
"The Situation"
Mclovin's Avatar
yea i dont think that would work.. all that back pressure might cause a few running issues.. not to mention feeding exh gas through your air tools
Old October 29th, 2009, 01:14 AM   #5
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
If you had enough blow by in the engine then you wouldn't have to worry about lubing them. I was just kidding with my suggestion by the way.
Old November 24th, 2009, 05:58 PM   #6
ronprice
ronprice's Avatar
318 360 dodges will run fine one four cyclenders. i have seen many made out of them. They make a head for them for this purpose.Left four run a nd right four pump.
ronprice is offline   Reply With Quote
Old November 24th, 2009, 07:37 PM   #7
GREASYHANDS
GREASYHANDS's Avatar
U can also do something simalar with the engine in your truck..... By removing a spark plug and replacing it with a compression tester end and air fiting u can air up in an emergency on the trail
Old November 24th, 2009, 07:44 PM   #8
forbyefore
forbyefore's Avatar
I've seen a few 302s set up this way. They will run 1" impact guns with 3/4" air lines with no problem. No waiting for the compressor to fill up the tank either. My father in law was telling me about an old radial airplane engine set up this way also, that has some serious cool factor.
forbyefore is offline   Reply With Quote
Old November 24th, 2009, 08:10 PM   #9
Ebs
Could you hard wire and use the starter to power the engine instead of using an electric motor and a belt?
Would you even need a cooling system for short durations of use? It's still creating heat from compression, but I imagine without any internal combustion that temps would be considerably lower.
Old November 25th, 2009, 08:37 PM   #10
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
the starter will overheat within mins.
Page generated in 0.48795 seconds with 54 queries
