93 S10 4x4 Tire question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 28th, 2009, 09:15 PM   #1
booblinker
Sore and Tired 24/7
booblinker's Avatar
Default 93 S10 4x4 Tire question
Anyone run 31x10.50s on stock rims with just cranking the torsion bars? I have read some things that say you need 3-4 inchs to do it, but no real world experience. I don't care if I can't go lock to lock, just needs to be drivable.
booblinker is online now   Reply With Quote
Old October 29th, 2009, 06:42 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
if you max out the bars. you'll fit but just barely
Old October 29th, 2009, 06:49 PM   #3
JohnL
Go until it breaks.
JohnL's Avatar
Send a message via AIM to JohnL
You don't want to max out your torsion bars. First off it would ride horribly and second you'd go through ball joints and TRE's like crazy. Also your CV shaft angle would be so terrible if you tried to put it 4 wheel drive they would snap in half.
I have seen blazers with a 3 inch body lift that fit 33's that would probably be the best route to go. You can get the body lifts for around $100.
JohnL is offline   Reply With Quote
Old October 29th, 2009, 06:50 PM   #4
chevy_4x4_trucks
chevy_4x4_trucks's Avatar
I had an old 89 s10 pick up and I ran 31s on it with the torsions cranked about 3/4 of the way
chevy_4x4_trucks is offline   Reply With Quote
Old October 29th, 2009, 06:56 PM   #5
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
I ran 33's with the torsion all the way up and 2" of body. Make sure if you do crank it up to add/remove some of the shims that change the castor and cambor of the wheel to help with the ride and the steering as well as wear and tear on other parts.
Page generated in 0.20613 seconds with 38 queries
