"Cheapthrill-EB buggy verision" -not so cheap anymore pg 65 - Page 60 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 16th, 2012, 10:38 AM   #1181
liv2mx
i like jungle gym's.
liv2mx's Avatar
how was that bill?
Old July 16th, 2012, 11:54 AM   #1182
With extra hose for trail spare, $170
Old July 16th, 2012, 12:17 PM   #1183
liv2mx
liv2mx's Avatar
yea seems to be the going rate. i looked at 4 different places.you get quickchange ends or the crimped on ones?
Old July 16th, 2012, 12:26 PM   #1184
Both...I need three more fittings, I bought them out of the one style.
Old July 16th, 2012, 01:33 PM   #1185
Running out of places to get more fittings. This would be easier if I had the crimping tool at home
Don't suppose if anybody has a good part number for valley or napa fittings? I think the parker fitting number is 20642-6-6 which valley or napa can't cross and the eaton number appears to be FC79880606S which they cannot cross either.
Old July 16th, 2012, 02:41 PM   #1186
Grassman
2jz specialist
Grassman's Avatar
call me, remember i got a hookup with hydraulics?
Old July 16th, 2012, 08:41 PM   #1187
All I need to do is hook up the cooler side of the orbital and I can bleed it out and pray it works . I also FINALLY rerouted my fuel filler neck. No more broken gas caps lol. Only took a 1.5 yrs and probably a dozen gas caps.
Oh and I bought WAY to much hose for my steering. Plenty for spares lol.
The orbital seals with o-rings, but on the other fittings should I have put teflon tape or similar?
Old July 17th, 2012, 09:04 AM   #1188
liv2mx
liv2mx's Avatar
when i did mine they told me to not use tape.
Old July 17th, 2012, 09:10 AM   #1189
FORD FLARESIDE
6'-1" 185lb 14YO Griffin
FORD FLARESIDE's Avatar
I've heard both ways............
However, I prefer to use teflon tape on my hydraulic fittings. I just make sure that I start the tape 1/8 inch up from the bottom of the threads.
Old July 17th, 2012, 07:28 PM   #1190
I has steering and so far no leaks. It is 2 turns one way to lock and 2.5 turns the other to lock.
oops
Climbing a tree and spotting yourself up the pass side is kinda hard to do Thankfully its only sheet metal and with no support to it it mostly just bends back into place lol.
just a little sidewall flex
Old July 17th, 2012, 07:41 PM   #1191
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
How's it feel?
Old July 17th, 2012, 08:22 PM   #1192
Really easy to turn, outside of that and only getting up to 10 mph an hour it felt similar other then effort.
Old July 17th, 2012, 09:07 PM   #1193
Ford rules
Ford rules's Avatar
Your rear leafs looks a lil worn out to lol!!
Old July 17th, 2012, 09:08 PM   #1194
Those are the new leafs lol. The old ones were "s" shaped .
I replaced my old ones with the same application "good" used ones. These newer ones lifted the ass 2"s from where it was , I think those old ones were pretty toasted.
Old July 17th, 2012, 09:52 PM   #1195
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Nice work John glad you got it done and it works had me kinda worried
Old July 18th, 2012, 10:08 AM   #1196
alboy79
Where's your loyalty lie?
alboy79's Avatar
He had three days... No worries.
alboy79 is offline   Reply With Quote
Old July 18th, 2012, 10:18 AM   #1197
Mr. Beefy
BFT!
Mr. Beefy's Avatar
"kinda" John is my hero
Old July 18th, 2012, 09:12 PM   #1198
$100 Orbital
$100 Ram
$220 fittings/hose etc...(enough hose left over to redo the whole thing and extra fittings to make trail repairs if needed.
$10 Fluid
$3 for pump reservoir extension from junkyard
Steel for mounts left over from other projects
Probably gonna buy a $40 cooler to add to it. I have a cooler already on it from the previous system, but its kinda small.
Old July 22nd, 2012, 02:16 PM   #1199
Steering worked well, developed a pin hole leak in the hose from the pump to orbital very early on, but since I used "field fittings" I was able to cut the hose back past the pinhole and reinstall the fitting and keep on going.
I did however manage to break my RR 14 bolt shaft.
ID:	94725   Click image for larger version
Old July 22nd, 2012, 02:27 PM   #1200
+1 for the hydro
-1 for the shaft
But it sounds like you guys had a good time.
Tags
about time to fricking, make a buggy already
Page generated in 0.37435 seconds with 84 queries
