"Cheapthrill-EB buggy verision" -not so cheap anymore pg 65 - Page 59 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 11th, 2012, 09:57 PM   #1161
I am committed now lol, trac bar mount has been cut off axle. I thought a single end would be easier to package.......At this point I think a double end would be easier. Single would be great if I had a high steer option.
Old July 12th, 2012, 10:17 AM   #1162
http://www.polyperformance.com/shop/...ts-p-2761.html
Ordered this the other day thinking I might be able to make it work for me. Reading that link, what do you expect to get when you order it? I got one bracket, not two.
I called trail gear as it appears to have been drop shipped from them and they said the part number ordered is for one bracket. I can't get poly to answer their phone. Unless I am missing something on poly's site I don't see anywhere where I should think anything other then recieving two brackets.
Old July 12th, 2012, 10:27 AM   #1163
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Looks to me there should be 2.
Old July 12th, 2012, 11:31 AM   #1164
4Bangler
Jackstand Wheeler
4Bangler's Avatar
"Steering ram mount brackets A nice set of heavy duty 1/4" plate steel brackets that are easy to install. On your tie rod (1.25") and axle housing. No grinding tabs to fit with these perfectly shaped brackets. Hole size 5/8". For use on 1979-1995 Toyota Pickups and 4Runners, may fit other applications."
Seems like a call to Poly would be in order....once they wake up of course.
Old July 12th, 2012, 11:46 AM   #1165
Yeah, left a message on their answering machine, and tried numerous times with both customer service and the phone order option. No answer or return calls yet.
Old July 13th, 2012, 12:09 PM   #1166
> I placed an order last week for item TRG-130254-1. I received the order
> Thursday the 12th. I was under the impression the item came as two
> brackets as stated in the description and no option to select one or the
> other led me to assume I was ordering both brackets. Since I could not
> reach ANYBODY at poly performance and the item appears to have been dropped
> shipped directly from Trail Gear I contacted them inquiring about the
> item. They stated the part number listed is only for the one diff bracket
> rather then both brackets as your site describes.
> *Steering ram mount brackets A nice set of heavy duty 1/4" plate steel
> applications.*
> Many attempts were made yesterday to call and figure out what had happened
> with no answer on either the order line or the customer service line. As
> well an attempt on Pirate to get a hold of somebody to assit me.
John these brackets are sold individually. I apologize that there was not a note on the page describing so. I will have that added right away however i cannot send you product which you have not paid for. So if you would like i can sell you the other bracket you require or i can e-mail you a return authorization and pre paid ship label to give you a full refund on the transaction. Please advise.
Thanks,
My response
Please send the return label and authorization. I understand it doesn't say
individually, but it clearly stated it was a set and described clearly there
were two brackets to the set.
Old July 13th, 2012, 01:02 PM   #1167
I copied the screen of the item in case they changed it without taking care of me, While the descrition has not changed, they raised the price $2 since yesterday at this time
In the return auth. form it even states "brackets".
Old July 13th, 2012, 01:24 PM   #1168
bluminade
Bluminade Has Arrived
bluminade's Avatar
now they will tell you that they can not return your money without you sending back both brackets.
bluminade is offline   Reply With Quote
Old July 13th, 2012, 01:32 PM   #1169
Thats what I was thinking
Old July 13th, 2012, 01:37 PM   #1170
montecarlo33
The Violator
montecarlo33's Avatar
customer service has been lost these days. I would have sent them back too. Love the build, good work.
Old July 13th, 2012, 09:17 PM   #1171
Mounts are just tacked for ram, cycle the steering left to right and clears everything..thoughts
Old July 13th, 2012, 09:39 PM   #1172
Ford rules
Ford rules's Avatar
Looking good!!
Old July 13th, 2012, 10:36 PM   #1173
liv2mx
i like jungle gym's.
liv2mx's Avatar
make sure you weld the poop out of those brackets. looks like it will work fine!
Old July 15th, 2012, 08:30 PM   #1174
Only picture I took while working today, axle mount for the ram. Got that wrapped up I hope, got the tie rod mount done, got the orbital mount done and attached to the column. I think I have my trac bar mounted, just need to check clearance and compression.
Tomorrow stop and get all the fittings and line to plumb the system and hope it works
I also need to come up with a way to stop the tie rod from spinning. Thinking maybe drilling out one knuckle to 3/4 and doing a dual hiem on that side and attaching the two to the dom.
Old July 15th, 2012, 08:56 PM   #1175
Grassman
2jz specialist
Grassman's Avatar
you gonna fix that bumpstop?
Old July 15th, 2012, 09:06 PM   #1176
Its already gone lol, needed to get rid of it to get access to weld. That was after the log jump in sand lake lol.
Old July 15th, 2012, 10:13 PM   #1177
nd4spd71
nd4spd71's Avatar
That mount looks kinda familar
nd4spd71 is offline   Reply With Quote
Old July 16th, 2012, 05:56 AM   #1178
A heavy durometer rubber bushing between the tie rod and steering arm does the trick. Just need it at both ends. JCR used to sell them, don't know if they still do. In reality, you can also stack some oversize washers in there or a tube spacer as long as there is a little play allowed. Just make sure you don't make it too thick so the taper won't cinch up. Been there, done that.
Old July 16th, 2012, 10:09 AM   #1179
liv2mx
liv2mx's Avatar
done yet?
Old July 16th, 2012, 10:25 AM   #1180
Just got back from kent rubber getting fittings and hose.
Tags
about time to fricking, make a buggy already
Page generated in 0.37987 seconds with 84 queries
