"Cheapthrill-EB buggy verision" -not so cheap anymore pg 65 - Page 44 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 9th, 2011, 08:02 PM   #861
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Ok so the chunk is not spun, the long side is?
Sounds like you got a good handle on it.
Old May 9th, 2011, 08:15 PM   #862
Yeah just the long side, thinking the come along and maybe a jack under the tie rod should give it just enough spin perhaps. Obviously have to loosen the radius arm at the mount to allow it to rotate.
Old May 9th, 2011, 08:20 PM   #863
jeepnxj96
jeepnxj96's Avatar
well it isn't completely to late for some sliders
Old May 9th, 2011, 08:23 PM   #864
Actually I am gonna remove the rockers at the bottom of the doors and with the fenders and install some 2x6 in place and tie to the frame. Eventually. But I need to fix the current pressing issue as I am leaving for drummond on thurs evening.
Old May 10th, 2011, 10:06 AM   #865
Well got the eb at the shop got the axle almost twisted back to place. Gonna be good enough. Thankfully my axle is got really good camber/caster adjustments in the upper ball joint.
This thing is really burning me out, I almost listed it for sale last night on classic bronco.
I bent the radius arm straighter, twisted the axle tube back best I could.
I need to replace both front axle seals.
Several front joint clips are MIA and several of the caps I tacked to the ears broke the tacks.
Old May 10th, 2011, 10:18 AM   #866
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Don't lose hope just yet, fix it and wheel it!
BTW, I have a good 10, 12' of 2x6 tube leftover from mine I will swing you a deal on.....
Old May 10th, 2011, 10:22 AM   #867
Aren't you in vegas?
Old May 10th, 2011, 10:30 AM   #868
liv2mx
i like jungle gym's.
liv2mx's Avatar
yea make sure your rear 14 bolt is welded on both sides of the tubes.those twist real easy.
Old May 10th, 2011, 10:31 AM   #869
Yeah the 14B is welded, not 360 but most of it.
Old May 10th, 2011, 12:55 PM   #870
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
LOL yeah, just catching up waiting for the wife to get ready.
Old May 10th, 2011, 04:08 PM   #871
All torn apart.
Front end all back together, just need to bring my rollers in tomorrow to do the alignment and still need to drain the rear diff yet.
Old May 11th, 2011, 05:44 PM   #872
Working on a stock bronco today and tomorrow at work.....its so tiny .
Old May 30th, 2011, 02:45 PM   #873
Went and played at a local spot for a bit today with kyle m, I first blew a RF brake hose (stainless braided), then broke the trans mount, then broke a front ujont strap which ate the joint. Then when put it on the trailer I noticed I am breaking the drivers radius arm and the pass diff tube spun again.
Old May 30th, 2011, 04:52 PM   #874
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
It was fun though!
Old May 30th, 2011, 06:23 PM   #875
deathbypsi
Brian R.
deathbypsi's Avatar
WTF is up with these axle tubes?
Old May 30th, 2011, 08:10 PM   #876
Shotgun
I only wheel with boats.
Shotgun's Avatar
eff it, weld them too!
Old May 30th, 2011, 08:41 PM   #877
thrill20
thrill20's Avatar
John, you should buy my duff arms... two more bushings to distribute that flex = less twist on thos axle tubes.
thrill20 is offline   Reply With Quote
Old May 31st, 2011, 06:39 AM   #878
Broke or spun? Time for that 3 link yet? You're 1 heim, 3 bushings and some Dom from having it in there
Old May 31st, 2011, 07:11 AM   #879
This is the radius arm to clarify not the axle tube.
Tags
about time to fricking, make a buggy already
Page generated in 0.45457 seconds with 85 queries
