"Cheapthrill-EB buggy verision" -not so cheap anymore pg 65 - Page 38 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 27th, 2011, 09:38 PM   #741
nd4spd71
nd4spd71's Avatar
Looking really good John. Can't wait to see it done.
nd4spd71 is offline   Reply With Quote
Old February 28th, 2011, 01:53 AM   #742
two_much_talk
sit down shut up and ...
two_much_talk's Avatar
Cool
Awesome as always John!
Looks like its really coming along. Look forward to seeing it in the dirt.
Old March 1st, 2011, 06:46 PM   #743
Got my power steering cooler, trans cooler, cooling fan and radiator mounted today. Need to run all the hoses and wire the fan and that should be squared away.
Also mounted the winch, need to pickup some more steel to finish the bumper.
Also stopped at the upullit yard and got some junk driveshafts with 1350 yokes.
Old March 1st, 2011, 07:53 PM   #744
pistol pete
I do vinyl stickers
pistol pete's Avatar
lookin good man
pistol pete is offline   Reply With Quote
Old March 1st, 2011, 10:25 PM   #745
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Looks great! How did you end up fitting/mounting the radiator? Did you cut the core support out? Looks like you added some angle.
Old March 4th, 2011, 11:15 AM   #746
disturbedsledneck
disturbedsledneck's Avatar
Badass build man! Subscribed
disturbedsledneck is offline   Reply With Quote
Old March 4th, 2011, 11:20 AM   #747
Yep, pretty much the center out and added angle top and bottom. I am using a 92-97 f-series radiator.
Thanks
Old March 6th, 2011, 07:04 PM   #748
After two years of running drums on the 14B I finally stepped up to the discs. I already had the calipers from a old project. So it was just the rotors and brackets. Rotors were $20 each and ruff stuff brackets.
Started out the day with doing the water pump. But like most Fords I have one damn timing cover bolt broke off. So looks like I will be getting a timing cover gasket set and gonna doing that as well as the water pump.
Built two rear driveshafts. Went to install my 1310 yoke on the front of the 205 and its larger then the cv style. I need to get a different seal.
Mounted the lap belts, need to get some tub and run a cross brace on the "b" pillar to attach the shoulder straps.
And worked some more on the front bumper thing..
Old March 12th, 2011, 09:05 PM   #749
I think I need longer air shocks
Trimmed the fender and header to clear the tires better at stuff......I found its really hard to make 104" wheelbase, 40"s tires, and not make it into a BDMT.
Got the radiator installed and hoses ran for that, powersteering, trans lines, mounted the battery, started routing the engine harness. Built the front driveshaft and checked it at full droop for binding. Installed bump stops in the front. etc etc etc
Old March 13th, 2011, 01:38 AM   #750
liv2mx
i like jungle gym's.
liv2mx's Avatar
looks like a big dumb mud truck...but it should wheel.
Old March 13th, 2011, 07:02 PM   #751
What a fawktastic day, started my traction bar......ran out of wire.
Started to wire in the taurus fan controller.....didn't finish it yet.
Attempted to start the eb only to find the ign. switch wasn't wired right so I didn't have a fuel. Figured that out, but it still won't start so no spark. However I didn't mess much with that due to having a torn inj o-ring so I was dumping fuel on the intake.
Got the exhaust y onto my manifold pipes, I have no idea how I am gonna fit a muffler and a pipe with the traction bar in the way.
And I called it a day .
Old March 14th, 2011, 10:34 PM   #752
Eb runs now, ign switch had some wires in the wrong spot. I had ign in the run position but when in crank it turned the ign off lol.
Also the trans cooler I picked up for a power steering cooler is a leaker .
Also got started on the traction bar.
I have an apt. weds to get the exhaust bent up for it.
Old March 15th, 2011, 06:20 AM   #753
I like it.
Old March 15th, 2011, 02:40 PM   #754
liv2mx
liv2mx's Avatar
here is some insperation for next year....
ID:	75936   Click image for larger version
Old March 15th, 2011, 02:46 PM   #755
Grassman
2jz specialist
Grassman's Avatar
sooooo your into dune buggies now?
Old March 15th, 2011, 02:48 PM   #756
liv2mx
liv2mx's Avatar
umm yea i would take eather of those... check out moui matt on pirate..he has had like 25 of the sweetest old bronco's.
Old March 15th, 2011, 05:44 PM   #757
jeepnxj96
jeepnxj96's Avatar
well at least you and Bigblockford79 have each other
Old March 15th, 2011, 08:42 PM   #758
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Careful jeep boy, our BDMT's might have to park on your matchbox car. HAHA
I feel your pains John, I did pretty much anything possibly to suck the height out of mine and you see what I ended up with. If I go the buggy route i will be able to be much more creative with certain issues but when you're working with a frame, its pretty limited.
Old March 15th, 2011, 08:43 PM   #759
It wasn't frame, it was more I didn't want to cut the eb all up so it wasn't easly recognized as a eb anymore
Old March 15th, 2011, 08:47 PM   #760
bigblockford79
Big Block Ranger
Gotcha, with mine it was frame, axle, and links intersecting.
Tags
about time to fricking, make a buggy already
Page generated in 0.42346 seconds with 84 queries
