"Cheapthrill-EB buggy verision" -not so cheap anymore pg 65 - Page 34 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 19th, 2011, 08:01 PM   #661
Yeah so someone buy his kingpin D60 so that he has money to do the rest of the stuff!
Old January 19th, 2011, 08:03 PM   #662
x2
Old January 20th, 2011, 04:31 PM   #663
KennyOffroad
Ridge Runners Offroad
KennyOffroad's Avatar
Are you done yet ?
Old January 21st, 2011, 06:57 AM   #664
superduty03
superduty03's Avatar
looks good man.... i love those early bronco's
superduty03 is offline   Reply With Quote
Old January 22nd, 2011, 10:04 AM   #665
KennyOffroad
Originally Posted by superduty03 View Post
looks good man.... I love those early bronco's
x2
Old January 24th, 2011, 07:47 PM   #666
Got my new heater core today from JBG. Stopped at central steel and got some misc stuff. STILL waiting on a package from ruffstuff though kinda holding me up.
Old January 28th, 2011, 09:54 PM   #667
Got my order from RuffStuff today so I can get some serious progress done this weekend. I also just got back from feva4u's shop. He helped me bend up my shock hoops the other day and we needed to but a little bend in them tonight to help clear the shock better from the frame.
Old January 28th, 2011, 10:51 PM   #668
Let me know if you need me to come over tomorrow and help get stuff lined up. I'll give you a call around 9:30 or so Thanks for the help tonight!
Old January 29th, 2011, 04:17 PM   #669
Old January 29th, 2011, 04:23 PM   #670
I need to figure out how to connect to my pitman arm, either by tie rod or something that will allow some steep angles.
Also gonna need to find a 45 or 90 for the fox shocks. Not sure I am gonna be able to get the line on as I am to close to the fender.
Old January 29th, 2011, 04:54 PM   #671
That doesn't look like full stuff What do you need for the shocks?
Old January 29th, 2011, 04:56 PM   #672
Its not, after I was done I let it down a bit.
The valve on the shock sits straight towards the fender. Not sure there is enough room to attach to the valve between it and the fender. Curious about a 45 or a 90 I can attach to get access.
Old January 29th, 2011, 05:01 PM   #673
Gotcha. Everything lay in nice? Cut some cardboard and come over and dimple die a piece to tie your shock brackets back to the hoops. It'll help keep them from coming off when you're airborn
Old January 29th, 2011, 05:11 PM   #674
Pass side hoop fit awesome first try, drivers side was a total cocksucker .
Old January 30th, 2011, 09:43 AM   #675
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Pitman arm fix for ya....
This is what I am running.
Then this as the tierod for lots of flex
Old January 30th, 2011, 11:48 AM   #676
I need to be below the pitman.
some more pics of checking clearances and what not at droop and compression. I DO NOT have my bumpstops installed yet.
Old January 30th, 2011, 01:20 PM   #677
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Looks sweet, gotta love those air shocks
build the pitman arm the other way then, so you can use a heim with double shear.
Old January 30th, 2011, 04:19 PM   #678
Rear shocks mounted
Start of the rear bumper
Crossover bar so far, notched it for the throttle linkage. Without the notch the throttle in sweep was a 1/4" away from it. But obviously the motor is gonna twist and move a bit so I wanted a little more "just in case" clearance. Need to make it removable next. Its just "in place" at the moment.
Old January 30th, 2011, 06:14 PM   #679
Made a list of to do stuff . Shooting for a badlands trip early April.
Do the air shock thing with the oil and nitrogen
Build steering (pitman to RF knuckle)
Build Front driveshaft
Build Rear Driveshaft
brakes
Build,modify, wire dash
wire engine compartment
wire lights
mount trans shifter
purchase/install cage
install seats
install build radiator/fan core support
finish rear bumper
build front bumper
figure out fuel system.
And I am sure I am leaving stuff out
Old January 30th, 2011, 06:45 PM   #680
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
That all seems doable. Maybe one of these days I will come down and lend a hand to help finish it up.
Tags
about time to fricking, make a buggy already
Page generated in 0.38273 seconds with 84 queries
