"Cheapthrill-EB buggy verision" -not so cheap anymore pg 65 - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 2nd, 2009, 08:05 PM   #41
for what?
Old November 3rd, 2009, 01:47 PM   #42
Brackets for the radius arm to frame and track bar. I am so sick of making brackets, this time around just gonna spend a few more $$ and buy them done.
Old November 3rd, 2009, 01:47 PM   #43
spent the first half of the morning raking leaves by the garage, just pushed the f250 into the garage.
Removed the exhaust manifolds from the 5.8L so I could remove the broken studs from the y-pipe and the gaskets were leaking on the block. Bolted the C6 to the motor and gonna drop it in shortly so I can get it out of my way and the weight on the susp. Gonna bring the 205 into work so I can remove the broken side mount bolts so I can build a support off the frame/crossmember for it.
I cut the old bungs out of my raduis arms and welded in the new ones. These should be a little harder to bend and yes this time around there will be no thread showing on the joint
Old November 3rd, 2009, 06:20 PM   #44
pistol pete
I do vinyl stickers
pistol pete's Avatar
thats gonna be one tough truck, hope to see it out at kennys when you get it finished
pistol pete is offline   Reply With Quote
Old November 3rd, 2009, 06:29 PM   #45
Front susp. is out and spent some time looking over the frame in the front with Feva4u. Looks like the front is gonna get stretched quite a bit. Looks like its gonna have almost zero approach angle. Also got my trans cross member just about planned out in my head.
Old November 3rd, 2009, 06:40 PM   #46
Yep, I think it's going to look good. Need to get that front axle moved forward, tack the spring perches on to see if you can run it there and then get the core support on to see what's in the way. I like how it's coming together. Should be able to keep it at stock height if everything works out for him.
Old November 3rd, 2009, 07:24 PM   #47
ksejeeper
Money pit
ksejeeper's Avatar
Send a message via Yahoo to ksejeeper
Originally Posted by jeepnxj96 View Post
this will be good
Dammit John, you are making us look bad, you will have yet another wheeling rig before half of us have our current projects done
x2
good start John
2012 Can-Am commander 1000 X
2014 Ram 3500 Meg Cab 4x4 6.4 Hemi Blacked out edition.
ksejeeper is offline   Reply With Quote
Old November 4th, 2009, 10:30 AM   #48
KennyOffroad
Ridge Runners Offroad
KennyOffroad's Avatar
Any updated pics ?
Old November 4th, 2009, 10:37 AM   #49
xj4life
xj4life's Avatar
with a flat belly that'd be pretty sweet
Old November 4th, 2009, 10:52 AM   #50
Yep I want it have a flat belly minus the radius arm mounts that extends the length of the flatness of the frame. More or less cover from the start of the trans to end of the tcase.
I only took two pics yesterday and they were shitty cell phone pics.
Old November 4th, 2009, 10:58 AM   #51
I have got two of four manifold studs removed from the manifolds and have got all three bolts drilled and tapped from the side mount of the np205.
Old November 4th, 2009, 11:16 AM   #52
Nice, It'll be as flat a belly as can be with a radius arm setup based on the explanation I got from John
Old November 4th, 2009, 11:18 AM   #53
drew91xj
drew91xj's Avatar
this sucks your building/built two rigs in the time it took me to get started on the idea of working on mine
Old November 5th, 2009, 12:26 PM   #54
Box from RuffStuff showed up today
Old November 5th, 2009, 12:34 PM   #55
KennyOffroad
NICE !
Old November 5th, 2009, 12:35 PM   #56
Pokerob
hug life
Pokerob's Avatar
only a box? weak.
Old November 5th, 2009, 01:11 PM   #57
Not just any box, but a box full of winter air, this way I can replace the summer air that are currently in my tires. After all I have to get ready for some winter wheeling .
Old November 5th, 2009, 01:16 PM   #58
Pokerob
hug life
Pokerob's Avatar
Old November 8th, 2009, 01:56 PM   #59
Got one gas tank dropped on the f250, most of the rearward frame is cleaned of brackets and useless bull shit. Modified the pass side front frame rail to work with my coil placement. Had to put a 1" BL on the cab though. Couldn't clear the tcase and do my flat belly skid without it. Unfort I snapped one body mount bolt and I need to get new bolts. But when I pulled up the floor mat, yeah not so solid. Gonna need a new drivers side floor board .
I'll have some pics later tonight.
Old November 8th, 2009, 05:03 PM   #60
Bench seat pulled and the buckets are just sitting in it. Nice smokers window eh lol.
Front of the frame
Stupid Bump in the frame, thats about where I want my coil bucket. Pass side
No more bump pass side
No bump anymore on the drivers side.
Unsuspecting surprise when I pulled the floor mats.
Alot of the extras removed from the frame. Getting ready to move the axle closer to the cab.
NP205 tucked up and out of the way, had to put a 1" BL on to get it to clear. This is where it will sit once done. Then I'll have a 21" wide skid plate protecting the uderside.
Tags
about time to fricking, make a buggy already
Page generated in 0.41324 seconds with 84 queries
