94 cummins that lopes?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 28th, 2009, 05:09 PM   #1
beejers
always building
beejers's Avatar
Default 94 cummins that lopes??
information: 94 cummins,automatic,150hp injectors,5'' exhaust
when I come off idle with light pressure on the go pedal the truck lopes, sounds like a really wild cam. it goes blaa,,,,blaa,,,,blaa. sounds like a hit and miss motor. when you give it a little more pedal it goes away. any ideas?
another issue that i have is that i was going down the road and the 10amp fuse that's inside the truck for the engine blew. i put a new one in, started it and as soon as i hit the gas it blew again. i put a 25amp in to get home, any ideas?
beejers is offline   Reply With Quote
Old October 29th, 2009, 08:16 AM   #2
moparman1231
Fsb4linked
moparman1231's Avatar
If nobody has info on here for you go to www.cumminsforum.com
moparman1231 is offline   Reply With Quote
Old October 29th, 2009, 01:28 PM   #3
beejers
always building
beejers's Avatar
i was going to sign up to that forum tonight so i can post some stuff. i was really hoping that someone here might know something.
Old October 29th, 2009, 01:40 PM   #4
mean_greenEXJAY
YJ now
mean_greenEXJAY's Avatar
lots of good forums on diesels, I like thedieselgarage.com. First thing I would do is take care of what ever is shorting out, now granted there isnt much wiring on a 12v cummins, it would suck to burn anything up, espesially that you put a 25a fuse in it.
With this miss, does it just sound wierd or does it lose power when it does it? is there any smoke when it does it? if so what color?
Old October 29th, 2009, 04:55 PM   #5
beejers
always building
beejers's Avatar
it does not lose power, but its only loping right off idle.
the idle problem has been going on since i bought it and the fuse issue just happened. i going to do the fuse first when i have the energy,i just got out of the hospital a few days ago.
Old November 17th, 2009, 04:12 PM   #6
Kegger83cj7
Kegger83cj7's Avatar
Did you ever get these issues figured out? My 95 CTD lopes the same way. I'm thinking the overflow valve on the injection pump, or return fuel lines????????????
Kegger83cj7 is offline   Reply With Quote
Old November 17th, 2009, 06:40 PM   #7
beejers
always building
beejers's Avatar
The fuse issue was the blue wire that hooks to the battery. the looping i have not figured out. i blew the rear brake lines and had to replace it all,rear lines,wheel cylinders,turn drums. i am going to get a appointment with a diesel shop soon. i am also going to advance the pump and add a fuel plate. i did hear some one say that it could be the big injectors without the pump being advanced but i dont know for sure.
Old November 17th, 2009, 07:26 PM   #8
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
I have the 75hp plate in mine. Along with the 3k gov spring kit. It makes a big jump in power.
Old November 28th, 2009, 07:22 PM   #9
DieselJeep52
DieselJeep52's Avatar
Send a message via AIM to DieselJeep52 Send a message via MSN to DieselJeep52
hmm i have 5x14 injectors in mine, cut delivery valves, different pump cam, and a 5kgsk and mine doesnt lope......
DieselJeep52 is offline   Reply With Quote
Old November 30th, 2009, 08:27 AM   #10
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
I would see what changes after you bump the timing. Alot of these trucks slip time. FWIW, I have not had that problem on either of my trucks (94 and 96) but I have not had the timing slip or ran aftermarket injectors (I use a #10 plate and 4k springs). I do have some 215 injectors I hope to install some day.
Also, if doing the timing, fix the kdp and loc-tight all of the timing cover bolts..
Last, I prefer the dtr forum.
RIP FULLSIZE4LIFE
Page generated in 0.29674 seconds with 53 queries
