SOLD***'80 CJ-5 Project***SOLD - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 28th, 2009, 10:24 AM   #1
4Bangler
Jackstand Wheeler
4Bangler's Avatar
Default SOLD***'80 CJ-5 Project***SOLD
I haven't worked on this in a few years, and today I am moving it into storage, if it doesn't sell before the storage barn is blocked by snow, it will not be available until spring, at which time I will most likely change my mind and keep it.
If you've been around a while, you may remember a build thread for this back on the old Michigan Jeeper's site.
This is a project Jeep that may take months, even years to finish, it is not a DD, it cannot be driven home, I will not deliver for any less than $0.34/mile both ways from Alpena, MI (read "off the edge of the earth), 500 miles max round trip.
I am intersted in $1200 cash, I am not interested in parting it out, I am not interested in trades for other peoples projects, paint ball stuff, car audio stuff, fish aquariums, or R/C trucks.
Acceptable partial trades include: '96-'98 Jeep low mileage 4.0L complete motor, '97 XJ doors, XJ long arm parts, 2-1/2" forged Johnny Joints, H1 wheel centers, 4.88:1 or 5.13:1 Dana 44 gears (LP and HP) Dana 44 lunchbox locker, handguns (have CPL), and vintage rifles.
The specs:
1980 CJ-5, unknown mileage, Orignal frame, blasted, and repaired with rect. tubing between motor mounts and front crossmember on both sides, rear cross member replaced with square tubing, gas tank mounts raised 1", round tube sliders welded to frame on driver's side, need finishing on pass side. Frame was painted with no primer and is starting to scale, should be easy to wire wheel and repaint.
Original body rear floor grafted to CJ-7 front cowl/dash with new full body sides, rect. tube "backbone" under cage "B" hoop, cut-down CJ-7 tailgate, rect. tube rear body sill. Body tub still needs a few patches and needs to be finish welded & seam sealed.
Good fenders, hood, grille (not the one that is pictured), and windshield frame (good glass).
"Lift-off" hood hinges and custom grafted "lift-off" winsheild frame hinges.
Flush-mount tail lights, reverse lights, and front turn signals.
4.3L TBI V6 with high mileage, new gaskets, ran good a couple years ago, new dual exhaust with Astro Van manifolds, two sets of engine front accesories.
New in box painless wiring TBI harness.
New in box Griffen aluminum radiator.
T-176 4-speed with new clutch, hydraulic release.
Twin-sitcked Dana 300 with short tailshaft.
Narrowed Chevy Dana 44 front axle, 4.11:1 gears, re-splined long side shaft, Dodge short side.
Nissan C200 rear axle with booty-fab disk brakes and rusty gears (useable?) SOA on stock YJ rear leaves up front, YJ leaves with CJ main out back, homemade copies of M.O.R.E. boomerang shackles, angled shock mounts on rear, square tube shock towers up front.
Custom dash with relocated glove box to clear cage, ammo can center console mounted to cage, nice CJ stamped low-back buckets, mounted to cage. Original straight column and tilt column. Factory roll bar with salvage front hoop and lower A-B spreaders made from another factory bar, cage needs finish welding.
Rectangle tube rear bumper with swing-out tire carrier on 1000lb hinge, adjustable tire height with spare hub, spindle, and lockout. Rec. tube front bumper with reciever for multi-mount winch.
Sitting on 33" MT rollers that hold air for 5-7 days, mounted on some vintage 6-lug "Duke-Boy" wheels that are probably worth more in scrap.
There are literally TONS of parts that go with, some of which are stored elsewhere. I do have a Scout II Dana 44 rear axle housing (housing only) that I will throw in with it if you're interested, or for a little extra $$ I have a 35-spline 5-lug semi-float Dana 60-2 rear axle with 4.11's that can go with it.
The pics:
4Bangler is offline
Old October 28th, 2009, 10:30 AM   #2
xj-james
Original Gangster
xj-james's Avatar
Nice project
Wish I had more time and $$. Good luck with the sale.
xj-james is offline
Old October 28th, 2009, 01:41 PM   #3
GLS
on the road
GLS's Avatar
pm sent
GLS is offline
Old October 29th, 2009, 03:55 AM   #4
4Bangler
Jackstand Wheeler
4Bangler's Avatar
Okay, I have one offer to buy it in the spring, anyone interested in working on it this winter? I'm taking it to the storage barn at 6:00pm tonight, so anyone that's seriously interested should PM me today, if I can keep it out of storage it might save YOU some money.
4Bangler is offline
Old October 29th, 2009, 02:39 PM   #5
4Bangler
Jackstand Wheeler
4Bangler's Avatar
If someone could commit to buying this before I put it in storage, or within the first couple weeks that it is in storage they could have it for $1000 cash, but I will need notification of your intent in the next few days.
4Bangler is offline
Old October 30th, 2009, 03:37 AM   #6
4Bangler
Jackstand Wheeler
4Bangler's Avatar
This is now in storage, take it away for $1000 until the end of November, otherwise it's $1200 in April or so.
4Bangler is offline
Old October 30th, 2009, 05:05 AM   #7
ArcticCat843
ArcticCat843's Avatar
Send a message via AIM to ArcticCat843
Wow, this is a good deal....To bad its the WORST time for me or i would buy it.
Im going to think about it for a couple days......If its still here i might see if i can scrape together the money but at this point its not looking good. I do have a set of clayton longarms. Less than 1000 miles old for a cherokee. Any interest in those? What about any other cherokee parts. I already sold most the driveline and the jeep is a 96 so the mirrors and interior door panels would be different than your looking for. Check out my XJ bumper thread though, see if you would have any interest in that.
ArcticCat843 is offline
Old October 31st, 2009, 10:00 AM   #8
4Bangler
Jackstand Wheeler
4Bangler's Avatar
Currently I have (1) cash/partial trade offer pending over the Thanksgiving holiday, and (1) tenative cash offer pending the outcome of a different transaction, so this is still up for grabs until someone makes a deposit.
4Bangler is offline
Old October 31st, 2009, 11:40 AM   #9
indytrucks
indytrucks's Avatar
Send a message via AIM to indytrucks Send a message via Yahoo to indytrucks
PM sent.
indytrucks is offline
Page generated in 0.42842 seconds with 50 queries
