I'm lost/ please help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 25th, 2009, 08:20 PM   #1
Rulebreaker
Cadillac Jeeper/ RPM
Rulebreaker's Avatar
Default I'm lost/ please help
I have a friend with a 88 sami with a carbed 1.3 with a header. The distributor quite working and it burns oil. He wants me to fix it for him. Can you buy a new pickup coil for these? Best place to buy? Any suggestions? Can you slip in a newer motor that is easier to find? I'm a Ford man so I'm lost working on this thing. Any help would be great. I called the junk yard and they said they could get me a distributor for around a $100 but they said there are two different distributors and I'm not even sure what this motor is out of but I'm guessing this thing had EFI originally. RB
Rulebreaker is offline   Reply With Quote
Old October 26th, 2009, 09:54 AM   #2
A4X4SPIT
A4X4SPIT's Avatar
any 1.3 will fit the trans a 1.6tracker engine (and the header&intake ) will fit with a trans adapter but you need a electric fuel pump. I have some 1.3 junk engines & I think some have distributors 88 sami had carbs (with lots of wires )I dont think they were even available with fi until the 90s
A4X4SPIT is offline   Reply With Quote
Old October 26th, 2009, 08:15 PM   #3
Rulebreaker
Where do you get the 1.6L adapter and what does it cost.
Old October 27th, 2009, 02:13 AM   #4
A4X4SPIT
A4X4SPIT's Avatar
you can get it several places llike trail tough . rocky road outfitters .about $150. altho Ive seen just engine ring for cheeper cant remember where
http://www.trailtough.com/index.php?...mart&Itemid=53
Old October 28th, 2009, 10:59 PM   #5
Rulebreaker
Ok so when my friend told me it died i told him it was probably the coil. So he had a mechanic look at it and the mechanic told him the ignition pickup thing in the distributor was bad. So i put a new distributor in it and I got no spark. Got power to the coil but no spark. Can i try a old ford coil or is this thing special.
Old October 29th, 2009, 08:20 AM   #6
A4X4SPIT
A4X4SPIT's Avatar
Ive used other coils i had layin aroundso Id try what ya got
Old October 29th, 2009, 08:23 AM   #7
Nuggets
I fix stuff!
Nuggets's Avatar
Put a 1.3 DOHC Swift GT motor in it and double your horsepower.
Old October 29th, 2009, 05:55 PM   #8
Rulebreaker
New distributor and coil and no spark. Got power to both. ?????????????????????? Any idea's?
Old October 29th, 2009, 09:50 PM   #9
jimmyroyse
webwheeler
jimmyroyse's Avatar
http://www.acksfaq.com/sessionTest1b-.php
http://bbs.zuwharrie.com
http://zukikrawlers.com
jimmyroyse is offline   Reply With Quote
Old October 29th, 2009, 10:19 PM   #10
Rulebreaker
I've messed with this rig most the night. This is what I know for sure. The wiring to the distributor was butchered so I went into this not knowing if I need a round plug or flat plug distributor. I bought the round plug one. I've got power to the distributor and coil via the black wire. I have continuity from the distributor to the coil threw the brown wire but I'm not getting a signal threw it to tell the coil to pulse. So either my new dis is bad or it's the wrong one. RB
Old November 7th, 2009, 08:41 AM   #11
A4X4SPIT
A4X4SPIT's Avatar
did you ever get it running ?
Old November 7th, 2009, 10:29 AM   #12
scottie
Eye candy
scottie's Avatar
It sounds like you put an EFI Dist on a Carb engine or vise versa, or EFI Coil when you should have a Carb Coil, or versa vice.
Post some pics of the engine compartment
Page generated in 0.32775 seconds with 59 queries
