How to fix holes in frame? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 23rd, 2009, 12:49 AM   #1
Tyler Dietz
Default How to fix holes in frame?
I working on a 1989 wrangler the rear frame has some holes in it and I would like to know what would be the east and quickest way to fix this?
ID:	51449   Click image for larger version
ID:	51450   Click image for larger version
Tyler Dietz is offline   Reply With Quote
Old October 23rd, 2009, 12:53 AM   #2
Jesse-James
Midwest Mudslinger
Jesse-James's Avatar
Jesse-James is offline   Reply With Quote
Old October 23rd, 2009, 12:57 AM   #3
Tyler Dietz
Not that easy or cheep ! What if I plate over it?
Old October 23rd, 2009, 02:45 AM   #4
NSmist
NSmist's Avatar
Send a message via AIM to NSmist
Might look at chopping where the rust holes are and welding on all brand new rectangle tube. No point in patching weak steel. Look at a few other YJ / TJ builds. Plenty of people have put new steel on their existing frames. POR-15 will become your new friend.
Looks like you've got more than enough patching all over that damn thing to keep you busy for a while
NSmist is offline   Reply With Quote
Old October 23rd, 2009, 08:33 AM   #5
mean_greenEXJAY
YJ now
mean_greenEXJAY's Avatar
That is almost as bad as mine
best way is to replace the back section of the frame with new steel, mabye work in a little rear stretch while your doing that. Also look at the frame where the steering box mounts, if that is pretty bad too, you may want to consider doing some else.
Old October 23rd, 2009, 08:56 AM   #6
Replace it. Here's what my 90 frame looked like in the back. It looked fine from the outside till I discovered I could ram a screwdriver through it. Notice how thin the material is down at the bottom.
Old October 23rd, 2009, 09:20 AM   #7
Yeah, thats the best way, cut it back until you can find good solid steel, and just replace the back section with tube.
Old October 23rd, 2009, 09:21 AM   #8
1badzuk
1badzuk's Avatar
go to lkq in dorr 300 and they have a nice frame
1badzuk is offline   Reply With Quote
Page generated in 0.31696 seconds with 48 queries
