8 lug to 5 lug dana 44 conversion - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Talk > Ford Tech > FAQ's
Old October 22nd, 2009, 03:07 PM   #1
curbdog17
Mini Van
curbdog17's Avatar
Default 8 lug to 5 lug dana 44 conversion
I have an 8 lug D44 from a 79 F250 I need to switch it over to a 5 on 5.5 bolt pattern. What parts would I need to do this?
Old October 22nd, 2009, 03:10 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
knuckles/calipers/caliper brackets/hubs/rotors
Old October 22nd, 2009, 03:11 PM   #3
Mr. Beefy
BFT!
Mr. Beefy's Avatar
You need the knuckles / spindles/ stub shafts / lockouts out of a f-150 + brakes
Mr. Beefy is online now   Reply With Quote
Old October 22nd, 2009, 03:14 PM   #4
curbdog17
Mini Van
curbdog17's Avatar
I have the factory flat top knuckles on this axle and wanted to keep them to do a high stear set up.
shit.
any one wanna trade parts to convert there 5 lug to an 8?
Old October 22nd, 2009, 03:17 PM   #5
Mr. Beefy
BFT!
Mr. Beefy's Avatar
The F-150 knuckles are flat top as well if I remember right I'm running 84 dodge 1/2 ton outers and they are flat top. And 5 on 5.5 bolt pattern
Old October 22nd, 2009, 03:21 PM   #6
curbdog17
Mini Van
curbdog17's Avatar
So I could use the Dodge 1/2 ton outers on this axle too?
If any one wants to trade parts let me know.
Old October 22nd, 2009, 03:25 PM   #7
Jeepaholic
Jeepaholic's Avatar
You don't need spindles or stub shafts if keeping with ford stuff, 99% of ford 1/2 tons are not flat tops.
If you want high steer and don't want to buy reid knuckles you can run; chevy/full size jeep knuckles/calipers/caliper brackets/small bearing spindles/stub shafts with ford 5 lug hub and rotor
Old October 22nd, 2009, 03:42 PM   #8
curbdog17
Mini Van
curbdog17's Avatar
this is the flat top right?
Old October 22nd, 2009, 04:19 PM   #9
Jeepaholic
Jeepaholic's Avatar
yes all the 3/4 ton fords had them but the 1/2 caliper will not clear the knuckle without major mods. You could redrill the 3/4 ton rotor to the 5 lug pattern and run the larger brakes.
Old October 22nd, 2009, 04:26 PM   #10
curbdog17
Mini Van
curbdog17's Avatar
By "major mods" do you meen alot of grinding?
If I was to do this would i just need 5 lug hubs/calpers/backing plate/rotors?
Old October 22nd, 2009, 04:31 PM   #11
Jeepaholic
Jeepaholic's Avatar
This is from Mr.N's site
Old October 22nd, 2009, 04:35 PM   #12
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Jeepaholic is the pro
I'm running 78 F-250 axle with stock iner shafts. Then 84 1/2 ton dodge outers. This includes knuckles, brakes, spindle, hub, alloy stub shaft, and they are both flat tops had the passenger side milled and drilled for high steer I'll snap a pic if you would like.
Old October 22nd, 2009, 05:13 PM   #13
curbdog17
Mini Van
curbdog17's Avatar
that would be great
It sounds like that may be what I have to do/or trade my parts for f-150 parts and forget the high steer.
Thanks for all the info everyone
Old December 2nd, 2009, 12:08 PM   #14
FORDTOUGH
FORDTOUGH's Avatar
I have been wanting to do the 8 lug swap on my d44 I would trade if you havent already. Only problem is my Bronco is my daily driver but im sure i could deal with it down for a day or two and I live in fowlerville.muskegon is a cruise. If you dont mind me asking why go 5 lug , only benifet would be 15" wheel ,maybe cheaper tires
FORDTOUGH is offline   Reply With Quote
Old February 27th, 2010, 06:16 PM   #15
95Bronco
Can you just install the 1/2 ton hubs/rotors on the 3/4 ton spindles?
Ignoring brake caliper mounting just for sake of discussion.
95Bronco is offline   Reply With Quote
Old February 28th, 2010, 11:21 AM   #16
curbdog17
Mini Van
curbdog17's Avatar
Yes
but look at my build thread because there are issues I ran into doing this swap.
http://www.greatlakes4x4.com/showthr...=156192&page=3
Old February 28th, 2010, 12:09 PM   #17
95Bronco
Thanks.
I think I've got a handle on what I'm doing now. Remember this is for a TTB Dana 44 not the solid 44. The TTB has six bolt spindles.
First swap to Chevy 3/4 ton knuckles. This will get me the 3/4 ton brake calipers, and Caliper mounts.
The bolt the Ford spindle to the Chevy knuckle. They are both 6 bolt
Then have the opening of a newer Dodge 1500 rotor opened up.
There is a little more to it than that but that is the general idea.
This will get me 3/4 ton size brakes while maintaining the 5 lug pattern.
I'm going to the parts store in just a few minutes to take a bunch of measurements on a few different rotors.
Old February 28th, 2010, 12:11 PM   #18
curbdog17
Mini Van
curbdog17's Avatar
Make sure your rims will fit over the larger brake rotors.
Page generated in 0.37630 seconds with 78 queries
