BFG KM2 Balancing... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 22nd, 2009, 08:13 AM   #1
kixx007
Certified Ypsilantian
kixx007's Avatar
Default BFG KM2 Balancing...
So I am mounting and balancing some 33x12.50x15 BFG KM2's.. Using 3M stick on weights.
It's calling for 7 ounces of weight on the inside of the rim. And uh, that seems like a lot for brand new rims and tires.
Anyone have experience with these? Are they like truxus' that take a TON of weight to balance.
kixx007 is offline   Reply With Quote
Old October 22nd, 2009, 08:22 AM   #2
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
First off what kinda balancing machine are you using? Does it have road force on it? At our shop we have the Hunter GSP9700 and when we have the same problemwe road force them. It will tell you if the wheel and tire have excessive road force. If the #'s fairly high we match the hard spot in the tire and wheel. It usually brings the weight back down. Why not use pound on weights and sticky?
Old October 22nd, 2009, 08:33 AM   #3
kixx007
kixx007's Avatar
Originally Posted by Hoss Blazer View Post
First off what kinda balancing machine are you using? Does it have road force on it? Sometimes @ our shop we have the same problem and we road force it and then match balance it and it will bring the weight down. Why not use pound on weight and sticky
Hunter GSP9200. No road force. Brand new machine, was re calibrated yesterday. Customer wants all weight on inside of rim. Doesn't matter if I use clip on or not, it still wants a TON of weight. I actually got it down to 5.25oz, but have you seen 5.25oz of sticky weight.
Old October 22nd, 2009, 08:39 AM   #4
Hoss Blazer
!SPARTY ON!
This is what we would do @ out shop put pound on weight on the inside and sticky on outside! Can your machine split weight? If so split the 5.25 and it's make it more reasonable! Then stick the sticky weight behind the face of the wheel! By the way its a wheel not a rim!!
Old October 22nd, 2009, 08:39 AM   #5
liftedandgifted
liftedandgifted's Avatar
You can always try static balancing it instead of alloy balancing it. I have never had a complaint on it yet even though I don't like that method too well.
liftedandgifted is offline   Reply With Quote
Old October 22nd, 2009, 08:43 AM   #6
Quagmire
I can has layinframe
Send a message via Yahoo to Quagmire
This is one of my 35x12.50 15 bfg mt
14oz of sticky weight rides fine they have been wheeling for 2.5 years since I have had them and Mike (wheelsofsteele) had them before me.
Google first.....ask questions later
Actually, the new rule of thumb is you should make your tires bulge slightly more then skooterbuilt when he's wearing his tight ladies pants
Quagmire is offline   Reply With Quote
Old October 22nd, 2009, 08:44 AM   #7
kixx007
kixx007's Avatar
Thanks for the correction.
Old October 22nd, 2009, 08:44 AM   #8
kixx007
kixx007's Avatar
I have 10. It looks close.
Old October 22nd, 2009, 08:48 AM   #9
swampfoxjr
Swamp Fox
swampfoxjr's Avatar
ive got 33-13.5/18 on my dodge with 18inch dc-1 and ive got 2lbs of weight on one tire
ive been told to use the powder or sand stuff that that works well, but its almost time to park the truck so ill worry about it next spring
swampfoxjr is offline   Reply With Quote
Old October 22nd, 2009, 08:54 AM   #10
Hoss Blazer
!SPARTY ON!
WOW!
I did some Irok radials that had the sand packs and bags tend to break open and make big ass mess!
Old October 22nd, 2009, 09:07 AM   #11
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
?sllab flog
@clarkstoncracker
Old October 22nd, 2009, 09:11 AM   #12
kixx007
kixx007's Avatar
?sllab flog
Golf Balls?
Old October 22nd, 2009, 09:11 AM   #13
kixx007
kixx007's Avatar
I got them balanced good enough for who they are for.
Old October 22nd, 2009, 09:12 AM   #14
Brian81CJ
Sellin' it all!
Brian81CJ's Avatar
Try dismounting the tire and rotating it on the wheel.
Brian81CJ is offline   Reply With Quote
Old October 22nd, 2009, 09:13 AM   #15
Pokerob
hug life
Pokerob's Avatar
Old October 22nd, 2009, 09:14 AM   #16
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Golf Balls?
Yep - did you have to hold the computer in a mirror to decode my post?
@clarkstoncracker
Old October 22nd, 2009, 09:16 AM   #17
Pokerob
hug life
Pokerob's Avatar
slla bem
Old October 22nd, 2009, 09:18 AM   #18
kixx007
kixx007's Avatar
Heck this machine does that for me. Well, actually, it just tells me where to rotate the tire too, I have to physically rotate it, but yeah. I did.
Old October 22nd, 2009, 09:19 AM   #19
kixx007
kixx007's Avatar
I turned around and read it in the mirror behind me.
Old October 22nd, 2009, 09:23 AM   #20
SweetLeah
<3's Ridin' Dirty
SweetLeah's Avatar
You're going to pay for that.
SweetLeah is offline   Reply With Quote
Page generated in 0.58887 seconds with 83 queries
