Transmission guys? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 22nd, 2009, 03:05 AM   #1
Disturban
Disturban's Avatar
Default Transmission guys?
1988 Suburban th400/350cid...I just picked up a 454 and am rebuilding it. I plan on dropping in the motor in the spring. Mild built with heads and cam 450-500hp. Questions, will my stock th400 be strong enough? If not what mods should I be looking at? Keep in mind that my truck see's a lot of different uses such as wheelin, towing, pulling people out of ditches...it is a work horse!
One more question...does my transmission have a computer controlled lock up converter? I am planning on running a carb and doing away with the computer...so if it does have a computer controlled lock up converter can I just swap it out with a converter from an early model th400?
Old October 22nd, 2009, 04:54 AM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
as for the trans the newer 400s are not the same as older ones. you should check http://www.tciauto.com/Products/GM/g...amatic_400.asp
as for parts anything that fit the `86 trucks should be usable on yours. I tend to wonder about the fuel sender? as I can't remember if it used an intank pump or a piggy back set up like the diesels did?
Old October 22nd, 2009, 05:50 AM   #3
Disturban
Disturban's Avatar
That does not tell me a whole lot...the main thing I need to know is if I have a lock up converter that is controlled by the computer? Other mods can be made later, my main goal would be to just get it going.
Old October 22nd, 2009, 06:04 AM   #4
Tom
Because racecar
Tom's Avatar
A th400 does not have lock up. What is the history of the stock th400? If it has a lot of miles on it, It wouldn't hurt to have it gone through and beefed up a little bit.
Old October 22nd, 2009, 06:09 AM   #5
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Ya what year is the TH400?? I'd get it rebuilt at the least, then tell who ever is rebuilding it what you plan on doing w/ it!
Old October 25th, 2009, 09:43 PM   #6
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Your trubo 400 is what they used behind the 454s back in the day anyway, a 4L80E is an electronic th400 just like the 4L60E is the electronic version of the 700R4/4L60
It should bolt right up and be usuable as is, though i'd reccommend a shift kit for the 400, it hold up better bolted to the 454. It doesn't have a computer controlled lock-up converter
Old October 26th, 2009, 07:53 AM   #7
Tom
Because racecar
Tom's Avatar
A 400 doesn't have a lock up converter period.
Old October 26th, 2009, 08:20 AM   #8
Disturban
Disturban's Avatar
Thanks...thats what I needed to know, I am good to go!
Old October 26th, 2009, 08:33 AM   #9
Tom
Because racecar
Tom's Avatar
one other thing to consider.... Is your truck currently a TBI motor? The kick down switch is actuated by the tps voltage and ecm on a TBI motor. That's easily fixed buy installing a switch from an earlier truck on the accelerator bracket.
Page generated in 0.34897 seconds with 50 queries
