Tire alignment - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 21st, 2009, 11:51 PM   #1
rob4407
rob4407's Avatar
Default Tire alignment
Today i took my jeep to get an alignment before winter just to find both of my outer tie rods are toast... Does anyone know if its possible to do the alignment myself after installing the new tie rods
Thanks, Rob
rob4407 is offline   Reply With Quote
Old October 22nd, 2009, 04:30 AM   #2
Disturban
Disturban's Avatar
You can get it close enough to drive it to an alignment shop. If it is not a daily driver and something you just beat up in the trails I would do it myself, get it as close as possible and call it a day. If it something such as a daily driver with good tires you for sure want an alignment shop get it balls on right.
Old October 22nd, 2009, 08:37 AM   #3
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Pretty much as said above. Also, I just tape measure most of my vehicles to 1/8 toe in and drive them. I don't see excessive tire wear, so it works for me.
RIP FULLSIZE4LIFE
Old October 22nd, 2009, 08:42 AM   #4
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
I'd just go get it alignment it's only gonna cost at tops $100!
Old October 22nd, 2009, 08:57 AM   #5
98BLKXJ
Do it yourself. 1/8" toe in and you will be golden! I aligned my Cherokee after installing the lift and the tires are wearing great and it IS my DD. 30,000 miles and only wore out 1/2 the tread.
98BLKXJ is offline   Reply With Quote
Old October 22nd, 2009, 09:06 AM   #6
junk90xj
ALLPRO AUTO
junk90xj's Avatar
just get the pro alignment. it will ensure your tires wear evenly and no problems exist
http://www.apalansing.com/
Old October 22nd, 2009, 09:19 AM   #7
269bigoldodge
269bigoldodge's Avatar
I used to do alignments. It will save you a lot money to just set it at 1/8" tow in. The only time you need to get a full alingment is when you replace ball joints or control arms.
269bigoldodge is offline   Reply With Quote
Old October 22nd, 2009, 10:35 PM   #8
shaggybowtie
count the number of times you turn the tie rod to get it out, thread new one in same amount of turns and this will get to pretty close, then measureto see if you have a slight toe in
shaggybowtie is offline   Reply With Quote
Page generated in 0.29923 seconds with 47 queries
