Push Button 4wd Blows...Fuses That Is - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 21st, 2009, 04:44 PM   #1
Ebs
Default Push Button 4wd Blows...Fuses That Is
Every time I hit the dash buttons it seems to either blow the fuse (t-case fuse) right away or it will shift into gear then blow the fuse.
I managed to get it shifted into 4Lo the other day, then got stuck in that gear as every time I pushed a button to shift into another gear it would just blow the fuse.
I replaced the t-case switch (the 2hi/4hi/4lo position indicator on the t-case) and it shifted back into 2hi right away when I hit the button, but that didn't seem to fix the problem as it is still blowing the fuse.
Any ideas?
I'm pretty much lost, I've replaced damn near everything that controls the t-case function. This as ruined me on the idea of electronic shi[f]t 4x4, I don't think I'll ever buy another truck with it again.
Edit: Forgot to add, its a '96 fullsize (NP243)
Old October 21st, 2009, 05:18 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
checked the wires going to and from everything? could be that either the t-case motor is bad or the front axle actuator is bad.
Old October 21st, 2009, 05:22 PM   #3
bigdogwaggy
bigdogwaggy's Avatar
i liked mine while i had it.. as for your problem i would check some wires.. sounds like one may be chaffed and grounding out when you put power to it. (pushing the button, telling something to change) i had something close to that whit my kc lights and had a wire that had rubbed through on the firewall.. but if you have replaced most things then i say check wires.. if not the "shift motor" may be going and being loaded it is straining to hard and poping the fuse.
bigdogwaggy is offline   Reply With Quote
Old October 21st, 2009, 07:46 PM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
the shift motors on the older one are real prone to moisture buildup and they corrode inside. I suggest you get a clamp on amp meter and check the circut load at the motor when shifting to see if its the source.
Yetti
Old October 23rd, 2009, 08:25 PM   #5
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
My Blazer does that when the T-case gets over full from the trans fluid seeping in past the bad input seal. Does youre trans fluid keep going low without an external leak? Pull the fill plug on the T-case and see if any fluid comes out.
Old October 25th, 2009, 07:15 PM   #6
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
i know this doesn't help, but this is why I like the 4x4 maunal shift....so much less to go wrong
Old October 25th, 2009, 10:28 PM   #7
devinbrown07
check the wires that are by the t case,i think its a set of 4 wires, maybe 3, well last winter mine was doing that, and the driveshaft somehow caught the wires and ripped them..
devinbrown07 is offline   Reply With Quote
Old October 29th, 2009, 07:19 PM   #8
Ebs
And I forgot to say, I've never had the 4wd working in this thing in the 2 years I've owned the truck. I replaced the t-case actuator, front axle actuator, and the dash button panel with used units last winter in an attempt to get it working.
It doesn't always blow the fuse, only when it actually tries to do something, much of the time nothing happens when I hit the buttons.
Where is the TCCM located behind the dash in these older body style trucks?
Old October 31st, 2009, 06:18 PM   #9
wave_crusher
I'll Direc your TV
that kinda tells me that the transfercase itself is bad
Page generated in 0.34890 seconds with 50 queries
