Winch solenoids - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 21st, 2009, 02:48 PM   #1
firehawk
Live Action!
firehawk's Avatar
Default Winch solenoids
I am replacing the solenoids on my Warn M12000 Winch and am wondering if the solenoids need to be hooked up in a specific way like the two smaller posts, or does it matter if I hook them up 180 degrees?
Are they polarity specific? One has an I next to it and one has a S.
I have two positions I can install it and dont want to fry the new solenoids.
If they need to be installed one way how do I tell which wire goes to which post?
Old October 21st, 2009, 06:21 PM   #2
cmays03
BUILD BY ME NOT BOUGHT!
try this not sure it its the right one but try it.
cmays03 is offline   Reply With Quote
Old October 21st, 2009, 06:27 PM   #3
firehawk
Live Action!
firehawk's Avatar
That is what it looks like. Just need to know if the solenoid is polarity sensitive, so I mean would it matter if it is positioned one way or the other, like 180 degrees of what is pictured. Assuming the wires stay in the same position.
I will just swap the wires the way they were to the new solenoid but it can be mounted two ways.
Old October 21st, 2009, 06:31 PM   #4
cmays03
so you are asking if you can mount it 180 off from what it is. if so i dont see why not.
Old October 21st, 2009, 10:16 PM   #5
Yota Bill
mounted position does not matter, wire position does
Old October 22nd, 2009, 12:22 PM   #6
firehawk
Live Action!
firehawk's Avatar
Well the wires are already where they are so it matters is what you are saying?
I know I can actually mount them anyway I want but without moving the wires does it matter?
What does the I and the S stand for on the solenoids and which wires go to which?
The old solenoids do not have the I or the S so I cant just match them up.
I have two options for the wires, one way or flip it 180 degrees. It will change what wires go to which post on the solenoid.
Old October 22nd, 2009, 12:22 PM   #7
firehawk
Live Action!
firehawk's Avatar
I am not confident in what you are guessing at so unless you have factual info I dont need to hear from you again.
Thx.
Old October 22nd, 2009, 11:43 PM   #8
Yota Bill
the I and S dont really refer to anything on the winch, thats for the original intended use of the solenoid...on a Ford vehicle...the I is for ignition, the S is for starter signal...
the S terminal gets a positive 12v to energize the solenoid and connect the two large terminals...the I terminal is used to supply voltage to the igntion system during cranking, if I remember correctly....
basically, the S terminal is the one that energizes the solenoid, the I terminal is a pass-through, used to energize the next solenoid (I am assuming that on the I terminal, since that is the only logical use for it)
if you wire it backwards, it may or may not work at first, but it will not work for long
Old October 24th, 2009, 10:12 AM   #9
firehawk
Live Action!
firehawk's Avatar
So I should find the hot 12v wire and hook that to the S and the the other to the I? Correct?
I tried hooking up a old solenoid and it worked both ways, pos to the S and pos to the I and the neg to the opposite and it worked both ways so I wasnt sure if it mattered at all.
Page generated in 0.21605 seconds with 50 queries
