question about angle grinders. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 21st, 2009, 02:13 PM   #1
kj kyle
kj kyle's Avatar
Default question about angle grinders.
I got my first angle grinder yesterday. I realize this is a pretty amateur question... but the cutting wheel i got is .045" thick, and when i tighten the nut on the arbor, it doesn't have enough threads to clamp the wheel in, place. however my grinding wheel is 1/4" and works fine.
is there some kind of spacer i need in order to use my .045" cutting discs?
kj kyle is offline   Reply With Quote
Old October 21st, 2009, 02:18 PM   #2
redxj_07
redxj_07's Avatar
usually if you flip the nut one way it mounts flush against the cutting wheel and the other way it will mount flush to the hub on the grinder. Try flipping the nut around.
redxj_07 is offline   Reply With Quote
Old October 21st, 2009, 02:18 PM   #3
Tab
Tab's Avatar
Usually you can just flip the outer nut around and it will tighten up that way.
Old October 21st, 2009, 02:19 PM   #4
Tab
Tab's Avatar
Damn, too late
Old October 21st, 2009, 02:21 PM   #5
kj kyle
kj kyle's Avatar
the back of the nut says "this side to housing" or something similar...
its a dewalt 10 amp 4 1/2" grinder
Old October 21st, 2009, 02:24 PM   #6
KartRacer
Blowd up
KartRacer's Avatar
Try flipping the spacer behind the disk.
Old October 21st, 2009, 02:25 PM   #7
kj kyle
kj kyle's Avatar
i was wrong.... it says this side to 1/4" wheel.
yall were right the first time.. thanks.
Old October 21st, 2009, 02:27 PM   #8
bhunt
BigBri
bhunt's Avatar
I believe you can order a whole new guard and nut for use with cutting wheel or you can just flip the stupid nut over.
bhunt is offline   Reply With Quote
Old October 22nd, 2009, 12:22 AM   #9
sabastian
what the hell is a gaurd?
sabastian is offline   Reply With Quote
Page generated in 0.40141 seconds with 50 queries
