1993, and 1980 bronco's - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Vehicle Part Outs
Old October 21st, 2009, 03:40 AM   #1
sandman86
sandman86's Avatar
Default 1993, and 1980 bronco's
i just picked up a 93 bronco and only bought it for the tub...odometer says 110,000miles has a 302 that run very well can see run before i pull it for you.
i'm pretty sure that it is an e40d trans seams to shift well. and has an electronic shift transfer case. no sure of the working condition of it.
truck has ac, and 4 wheel abs.
like i said i'm only using the main tub and dash...
302-$400 obo
trans- $200 obo
tcase- $100 obo
hood, lil rust across leading edge... $100 obo
cap, has the wind deflector/ spoiler $200 obo
tail gate- looks like some one backed in to something with the spare tire carrier, but looks like all the internals are in good working order- $150 obo
spare tire carrier-$150 obo
the spare tires looks to be in great shape& holding air. $50
the 4 tires on the truck are junk but hold air. would make good rollers-buy something else and want them there yours free...
also have a
small block c-6 needs rebuild- $50
92 f150 single cab, has tittle, rusty cab corners/rockers, no windshield/ missing one slider window, have doors not mounted.- $150 obo
92 f150 single cab short bed frame. ttb was removed for sas never finished. bare frame only, no suspension.- $100 obo
late 80s short box...solid but rusty... $150 obo
ill get pics of whatever any body wants!
90% of these parts are located at my home in warren. the f150 frame is in Shelby township(there's a forklift there to load it)
sandman86 is offline   Reply With Quote
Old October 21st, 2009, 12:31 PM   #2
MilwaukeeF350
Dan
Is small block C6 4wd or 2wd?
Do you have driveshaft for C6 in bronco? I have bronco with AOD but not sure if they are same length.
Old October 21st, 2009, 12:44 PM   #3
sandman86
sandman86's Avatar
forgot that lil tid bit of information, all my trans are mated 4x4 and all where from trucks with manual shit t-cases
my brown bronco has a c6 in it, but id like to retain my 4x4 for the time being until i pull the ttb off
how long of a drive shaft do you need? ill see what have laying around
(i scraped a 86 f150 4x4 with an aod and still have the shafts somewhere...)
Old October 21st, 2009, 12:50 PM   #4
MilwaukeeF350
Dan
I have drive shaft but I am not sure if it would fit C6 because different length from AOD?
Ok what wrong with bad C6? slipping?
Old October 21st, 2009, 02:25 PM   #5
sandman86
sandman86's Avatar
oooh i get it, lil slow on the uptake today...
i bought it used with out the tail housingand never had it in a truck bought a tail housing and was going have it built up but then found the built trans to use... now I'm using nether. id just say it needs a rebuild so i don't sell a "good"trans... and piss some one off...
Old October 22nd, 2009, 08:12 PM   #6
sandman86
sandman86's Avatar
Bump
Old October 22nd, 2009, 08:21 PM   #7
84cj7
84cj7's Avatar
93 driver door?
84cj7 is offline   Reply With Quote
Old October 23rd, 2009, 02:05 AM   #8
sandman86
sandman86's Avatar
i have a blue one, manual window/manual lock. pritty solid, ill get pics tomarow.
Old October 23rd, 2009, 07:21 AM   #9
Blazin79
Blazin79's Avatar
80's doors? shape and prices?
Blazin79 is offline   Reply With Quote
Old October 29th, 2009, 01:17 PM   #10
Do you have a fiberglass top with over theshoulder type seat belt restraints?
Old October 29th, 2009, 02:06 PM   #11
sandman86
sandman86's Avatar
yea the white bronco has that style top
80s doors are rusted/ rotted out at he botoms... if you really want them $50 for the pair...
Old October 29th, 2009, 02:15 PM   #12
Old October 29th, 2009, 02:45 PM   #13
sandman86
sandman86's Avatar
i have it listed in the fist post for $200 its white i color. just checked the seat belts are unbolted from it. but there in the truck i bet i could look thru the pile of parts in the "bed" and find the bolts...
Old October 29th, 2009, 02:50 PM   #14
I'll let you know, I skimmed the first post I must of missed it.
Old December 1st, 2009, 09:36 AM   #15
fordboy
any seats?
fordboy is offline   Reply With Quote
Old December 13th, 2009, 07:15 PM   #16
IDIeselman
IDIeselman's Avatar
Is the 1980 bronco frame for sale also?
Old January 11th, 2010, 06:23 PM   #17
TAZ03DAK
HA!
TAZ03DAK's Avatar
Im looking for front coil spring buckets, would you be willing to part any out?
TAZ03DAK is offline   Reply With Quote
Old January 13th, 2010, 07:33 PM   #18
livetoride88
livetoride88's Avatar
im looking for a set of rear leaf springs off either of the two broncos u have there
livetoride88 is offline   Reply With Quote
Old March 14th, 2010, 10:13 PM   #19
sandman86
sandman86's Avatar
sorry guys i don't get on here often to check this. i would appreciate pm's...
but change of plans. im selling the 1980 bronco out right. still parting out the stock suspension on the 93.
i pmed the last 3 posts.
Page generated in 0.36961 seconds with 80 queries
