H1 tires and wheels SOLD - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 20th, 2009, 09:12 PM   #1
sonoma944
HOTROD
sonoma944's Avatar
Default H1 tires and wheels SOLD
Set of 4 37 12.50 16.5 goodyear mtrs on h1 12 bolt bead locks, tires are 99% tread left.
thanks, Nate 231.638.7761
$1100
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
sonoma944 is offline
Old October 20th, 2009, 09:22 PM   #2
mean_greenEXJAY
YJ now
mean_greenEXJAY's Avatar
what kind of inserts do they have
mean_greenEXJAY is offline
Old October 21st, 2009, 01:36 AM   #3
sonoma944
HOTROD
sonoma944's Avatar
I have no idea, is there a way to tell without tearing them down?
Old October 21st, 2009, 01:54 AM   #4
MiNi Beast
MiNi Beast's Avatar
Not to bad of a deal to check really, just let the air out and unbolt the nuts and pull the plate off and you will be able to tell weather rubber or magnism.
MiNi Beast is offline
Old October 21st, 2009, 03:21 AM   #5
creeping death
I'm that guy.
creeping death's Avatar
are the tires bias or radial?
bias = mags
radial = rubber
your wecome.
creeping death is offline
Old October 21st, 2009, 03:23 AM   #6
MiNi Beast
MiNi Beast's Avatar
radial tires so rubber inserts then
Old October 21st, 2009, 08:00 PM   #7
1twisted1
1twisted1's Avatar
have the rims been re centered if if so with what back spacing???
1twisted1 is offline
Old October 21st, 2009, 08:07 PM   #8
MiNi Beast
MiNi Beast's Avatar
they are the original stock H1 rims from the military.
Old October 21st, 2009, 08:19 PM   #9
Renegade II
Coil springs are for pens
Renegade II's Avatar
Are those Unicure Goodyear tires? I don't recall Goodyear making 37" MTR's in a 16.5" rim size, only 17".
Renegade II is offline
Old October 21st, 2009, 10:48 PM   #10
sonoma944
HOTROD
sonoma944's Avatar
7 inch back space
Old October 21st, 2009, 10:49 PM   #11
sonoma944
HOTROD
sonoma944's Avatar
yes those are the same tires from that sit, about 1 1/2 old
Old October 24th, 2009, 07:06 AM   #12
sonoma944
HOTROD
sonoma944's Avatar
bump
Old October 24th, 2009, 08:08 AM   #13
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Stock backspacing- origional wheel centers are there. If I remember correctly it's 6 3/4".....
bias = mags
radial = rubber
your wecome.
It could be the PVC inserts from Stazwerks too...... But I would bet that they are the rubber ones like I have....
SANDVIPR is offline
Old October 25th, 2009, 06:44 PM   #14
sonoma944
HOTROD
sonoma944's Avatar
bump
Old October 25th, 2009, 07:15 PM   #15
jmdzuk
jmdzuk's Avatar
with no air ,I would almost think you could bounce/push down on the tire and feel the insert.If its ruber or solid metalic
jmdzuk is offline
Old October 25th, 2009, 07:16 PM   #16
jmdzuk
jmdzuk's Avatar
Oh and the Military is not selling this off any more.They are going to be harder to get
jmdzuk is offline
Old October 26th, 2009, 07:13 PM   #17
sonoma944
HOTROD
sonoma944's Avatar
bump
Old October 28th, 2009, 08:34 AM   #18
sonoma944
HOTROD
sonoma944's Avatar
bump
Old October 28th, 2009, 09:15 AM   #19
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
bias = mags
radial = rubber
your wecome.
This would only apply if they were original military tires and even then it is not guaranteed.
Aftermarket tires, they may not even have the runflat anymore. USUALLY a 12 bolt H1 wheel will have a rubber runflat. But they could have been switched or eliminated. They could be cut down to no runflat, PVC, or Stazworks even.
For a 12 bolt set of wheels, that is a damn good deal with 95% tread that isn't rotting on the rims.
jeepfreak81 is offline
Old November 2nd, 2009, 07:10 PM   #20
sonoma944
HOTROD
sonoma944's Avatar
bump
Page generated in 0.37428 seconds with 83 queries
