89 Ford F-150 Stalling then not starting - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 19th, 2009, 11:10 AM   #1
biohazardbill
The Biohazards
biohazardbill's Avatar
Default 89 Ford F-150 Stalling then not starting
My Dad brought over his truck for me to do a tune up on. It stalls sometimes and sometimes when it stalls it wont start for about 10-15 minutes. It also has a very low idle. It also lacks power and gets about 8 mpg. I asked if anything had been done to the truck and he stated that a guy he knows tried to "adjust the idle" while he was in the hospital. It is FI not carbed so im not sure what the guy tried to adjust... maybe the timing?
We have the stuff to do a minor tune up but im thinking that isnt going to solve the problem. I am also going to check the timing.
How do you time these vehicles.. the sticker says to disconnect something but im not sure what they are referring to when timing to 10 degrees BDC.
Any ideas?
Thanks in advance
biohazardbill is offline   Reply With Quote
Old October 19th, 2009, 11:18 AM   #2
clarkstoncracker
lol
clarkstoncracker's Avatar
adjusting the idle would mean adjusting the TPS I'm guessing
Old October 19th, 2009, 11:25 AM   #3
Bow_Extreme
Bow_Extreme's Avatar
He probably pulled the plastic cover off the top of the throttle cable and adjusted the idle screw position. These motors are notorious for gumming up in the top end. The idle speed motor is probably gummed up, the EGR system is probably plugged and may have rotted pipes on the back side of the motor. The entire plentum is probably caked. If you remove the intake hoses from the front of the plentum you will see the very black residue left behind. I'm assuming you have the 302 in this vehicle? If the internals are caked up it's probably a good idea to remove the plentum, idle speed motor, EGR system, etc. and work on cleaning these items. I actually took the plentum off one of my 302's, to an engine shop and had them clean it for me. I also removed the intake manifold and had it cleaned as well. It's a bit of a job but generally worth it in the long run.
Bow_Extreme is offline   Reply With Quote
Old October 19th, 2009, 12:50 PM   #4
biohazardbill
The Biohazards
Sorry it is the 5.8
I will check this out.....
Old October 19th, 2009, 11:19 PM   #5
Yota Bill
the spout that you need to remove is a small grey plastic shorting bar, should be near the distributor, it may have some tape wrapped around it or be taped to the harness if it has never been removed before.
x2 on cleaning the air intake system, along with the EGR and idle air bypass vlave...try using a cleaner that you can spray in as its running first, if that helps, but doesnt clean it out all the way, then you know that tearing it apart isnt a waste of time
Old October 20th, 2009, 08:52 AM   #6
7.3X
Fullsize support vehicle
7.3X's Avatar
X2 on cleaning it out. It most likely needs it.
7.3X is offline   Reply With Quote
Old October 20th, 2009, 09:17 AM   #7
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
you might also check the fuel pressure and fuel pressure regulator when that regulator starts going bad it can cuase all kinds of issues
broncobuddha is offline   Reply With Quote
Page generated in 0.32607 seconds with 44 queries
