fuel pump issues! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 18th, 2009, 09:41 PM   #1
mwabbe
Default fuel pump issues!
i have a 2002 alero and the fuel pump is only turning on time to time could the ignition switch have anything to do with this?
mwabbe is offline   Reply With Quote
Old October 18th, 2009, 09:45 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
check grounds first. they commonly go bad on every vehicle that sees salt.
Old October 18th, 2009, 09:47 PM   #3
mwabbe
i finally took it in and the guy at the shop said that he droped the tank and all the wires looked good.
Old October 18th, 2009, 09:51 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
just cuz the wires by the tank are good doesn't mean you don't have a bad ground. the PCM controls the fuel pump that could have a bad ground, there could be a bad engine to body ground or a bad battery to body ground. just giving you ideas of other things to check. could also be a bad or shorted relay.
Old October 18th, 2009, 09:55 PM   #5
mwabbe
yeah i changed the rely to be safe and my battery is bad. do you know where the ground wire would be on this type of car?
Old October 18th, 2009, 10:03 PM   #6
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
look at the negative cable from the battery. it should have a large cable going to the engine and a smaller one that will go to the body nearby. if you have a dead battery then that can also cause your problem.
Old October 18th, 2009, 10:06 PM   #7
mwabbe
does the fuel pump have a ground to the body
Page generated in 0.23233 seconds with 44 queries
