isuzu dana 44 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 18th, 2009, 04:32 PM   #1
cloud9tj
cloud9tj's Avatar
Default isuzu dana 44
I picked up a dan44 out of a isuzu rodeo has 4.30 gears in it i want to put 4.11 in it to match my front axle any suggestions thanks
cloud9tj is offline   Reply With Quote
Old October 18th, 2009, 04:38 PM   #2
MiNi Beast
MiNi Beast's Avatar
You need to get the closes numerical number available, which I think it is like 4.13 and that should work for you.
Old October 18th, 2009, 04:47 PM   #3
Bishop
Bishop's Avatar
Just leave it and run different size tires.
jk, x2 on what MB said.
Old October 18th, 2009, 06:12 PM   #4
cloud9tj
cloud9tj's Avatar
guss what I need to know is are these things just a standerd dana 44 or not
Old October 18th, 2009, 06:23 PM   #5
MiNi Beast
MiNi Beast's Avatar
from pirate...
Iszuzu Dana 44?\\\\\\\\\\'s - Pirate4x4.Com Bulletin Board
my rear D44 is off a 95 Isuzu Rodeo...
- 58" WMS to WMS
- factory disk brakes
- 6 lug
- 30spline
- larger than normal axles that neck down to normal size.... this only helps load weight, not rotation force.
- both axles are same length
Overall, it is a normal rear D44 with the exception of the yoke. It has a flange mount yoke... but it can be replaced with any stardard D44 yoke, which is what I did...
the 98+ Isuzu D44s use a thicker ring gear than normal and can be had in 4.10 and 4.30 ratios stock depending on transmission. because of the thicker ring gear however you have to use the arb for the 3.93? and numerically lower gears even tho the ratio is numerically higher. a few of the isuzu guys have run into this problem. IIRC the ARB for the Isuzu is the RD07. One person i know has converted it to full floater, but it took so much work i'm not sure it was worth it, tho it did save him when he blew a R&P in moab in october.
http://www.4x4wire.com/jeep/tech/axle/xj_dana44_02/
Old October 18th, 2009, 06:49 PM   #6
cloud9tj
cloud9tj's Avatar
thanks thats what i was looking for,I picked this up the other day cheap,but my waggy front dana44 has the 4.11s not sure if im gonna change those or the isuzu.
Page generated in 0.24645 seconds with 42 queries
