divorced BW 1356 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 16th, 2009, 01:23 AM   #1
camccardell
tiger blood
camccardell's Avatar
Default divorced BW 1356
IS this possible? I mean seriously.
I would love to have a divorced bw1356 if it is possible.
I can't find a 4x4 alison transmission for a 3.9 ISB cummins, and even if I could, I doubt it would be cheap.
I'm not looking to spend $4000 on a new trans and trasfer case out of a dodge either, so there has to be a cheap way to do this
any ideas?
Old October 16th, 2009, 09:35 AM   #2
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I've seen posts of guys using the ZF trans out of a F250 for their cummins swaps when I was searching for a 4x4 ZF for my 250.
@clarkstoncracker
Old October 16th, 2009, 10:13 AM   #3
7.3X
Fullsize support vehicle
7.3X's Avatar
Not currently possible (without a lot of money) there was never a divorced 1356 case they are made out of magnesium and not aluminum. The case is not designed to support itself not to mention it is weak in the rear bearing retainer area and they tend to crack and leak there. Also the manual shift 1356 t-case is reasonably strong and reliable just keep it tight to the trans adapter and make sure the output bearing retainer is in good shape.
A ZF 5-speed from 97 to 07 models s542 or s547 come with the NV 271 or the electric shift 273 which is a little heavier but a lot stronger. Good luck.
7.3X is offline   Reply With Quote
Old October 16th, 2009, 10:28 AM   #4
camccardell
tiger blood
well a stick shift is out of the question.
A dodge automatic with the 273 might work, depending on cost.
Do you know if you can use the 273 with the dash controls for the bw1356?
Old October 16th, 2009, 10:56 AM   #5
Pipeliner_86
Pipeliner_86's Avatar
Why not a divorced NP205? They're not that hard to find, and they don't come much stronger than that.
Also, bread trucks sometimes had 4cyl cummins in them with a chevy turbo 400 trans behind it. If you could find one of those, you could always gut the th400, put a 4x4 tail end on it and go with a chevy style t-case.
Just throwing ideas out there, I don't know the specifics of your project.
Pipeliner_86 is offline   Reply With Quote
Old October 16th, 2009, 11:01 AM   #6
camccardell
tiger blood
I still think I might want to try this.
Anyone have any busted or junk bw1356 t cases?
I think I'll need an e4od output shaft or one that will work from a diffirent trans.
Old October 16th, 2009, 11:03 AM   #7
camccardell
tiger blood
I appreciate the info, but I want to retain the electric transfer case, and I also want to have overdrive.
I want it all, lol
Old October 16th, 2009, 11:08 AM   #8
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
I thought I remember reading that the gm allison is based off of the medium duty 345? I think is the model. Maybe look into using a tail housing off of one of those on a medium duty allison?
Old October 16th, 2009, 12:25 PM   #9
fsumotorhead
N8KVB
fsumotorhead's Avatar
there is a ford small block transmission adapter for the isb bellhousing which i believe is an SAE #3 housing
how to get one, or what they cost is beyond me
Old October 16th, 2009, 04:20 PM   #10
7.3X
7.3X's Avatar
I have an E4OD output shaft you can have. Also give me some more info on what your trying to do maybe I can find some parts.
Old October 16th, 2009, 06:06 PM   #11
camccardell
tiger blood
that would be awsome man!
I am going to try to machine a plate that will go on the imput side of the transfer case that is also the bracket for bolting it to a crossmember.
I will also add a tube for a bushing, seal, and the input shaft that I want to make out of an outpput shaft off an E40D. I want splines and threads on the other end, so I can add a yoke.
Any junk bw1356 would be good for a mock up
Old October 17th, 2009, 03:25 PM   #12
Daddy Dan
SBF Nut
Daddy Dan's Avatar
I could get one. Got a buddy with a couple torn down right now. One needs everything rebuilt. Maybe we could work out a meet and trade for those Michelins.
Daddy Dan is offline   Reply With Quote
Old October 17th, 2009, 11:33 PM   #13
camccardell
tiger blood
no trade for a junk tcase
junk tcase isn't worth more than a pack o beer!
Will sell em though
Old October 23rd, 2009, 06:36 PM   #14
camccardell
tiger blood
I still need a e4od output shaft
you get my PM 7.3x?
Old February 4th, 2010, 11:18 AM   #15
camccardell
tiger blood
got bored due to the weather, and started teaching myself CAD.
Came up with a few ideas for some brackets, and adapters.
With this one, I can use a stub shaft I made and use a stock d44 pinion seal and yoke.
I might turn the mount around and have a crossmember directly underneath it, or I'm thinking it would work better over the top of the t case.
Page generated in 0.29295 seconds with 68 queries
