HID Xenon Headlights - digital slim ballasts locally - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Vendors
Vendors Companies That Deliver Great Products Or Services and a list of companies offering GL4x4 Discounts
Thread Tools
Old February 3rd, 2010, 11:37 AM   #81
MUDBOG101
MUDBOG101's Avatar
Originally Posted by BooGTS View Post
No, he was the only one to have the issue and we never figured out why. Usually its due to a bad antenna or ground. You get a very slight bit of interference on weak stations with any install, but nothing of note.
im actually not the only one with this problem, alix4d and orvoffroad has the same issue, doesn't really bother me much though so im not too worried about it, (my grounds are perfect in my jeep just cleaned them not to long ago plus i have a 0gauge body ground and the grounds for the hids are both ran directly too the battery, and there is nothing wrong with my antenna) but anyways Ryan i was wondering how much for a 9006 and 9005 kit for a 99 grand cherokee 55w 5000k
MUDBOG101 is offline   Reply With Quote
Old February 5th, 2010, 09:17 PM   #82
BooGTS
Boost Withdrawl
BooGTS's Avatar
Hrm, they never told me so I assumed you were the only one. Got me - I have 4 ballasts on my Jeep and don't hear anything on local stations.
Have a 9006K kit in 50W for $90 (its a fluke, normally I don't carry 50k in this) at 6000K, will be same color as 5000K 35w, and then the 9005 5000K would be $70, and I'll throw in a relay harness as I think you'll need to for a grand. ($160 total)
BooGTS is offline   Reply With Quote
Old February 6th, 2010, 07:53 AM   #83
Blue XJ
The Green Machine
Blue XJ's Avatar
Send a message via AIM to Blue XJ
im actually not the only one with this problem, alix4d and orvoffroad has the same issue.
I have that problem as well, 89X gets completely wiped out when I turn my headlights on. My grounds are in good shape, seeing as how I just built the jeep a year ago. I'm planning on playing around with wiring harness a little this weekend so try and help it.
Blue XJ is offline   Reply With Quote
Old February 6th, 2010, 11:56 AM   #84
EMAXX620
EMAXX620's Avatar
Send a message via AIM to EMAXX620 Send a message via MSN to EMAXX620
I cant say i have that problem with my headlights on. I usually leave on 101.1 though. Next time im out, ill toss on 89x and see if theres any effect. I know ive been thru the stations and cant remember hearing anything.
EMAXX620 is offline   Reply With Quote
Old February 6th, 2010, 02:15 PM   #85
Blue XJ
The Green Machine
Blue XJ's Avatar
Just about all the other stations come in just fine, 101 works on mine.
Old February 7th, 2010, 05:06 PM   #86
EMAXX620
EMAXX620's Avatar
listened to 89x for a while and didnt notice any static, ill mess with it a bit more over the next few days and post
Old February 16th, 2010, 12:42 PM   #87
johnyk440
johnyk440's Avatar
Default HiD headlights
I am looking to put HID in my 2000 XJ. I already have Delta Xenon Headlights, http://www.quadratec.com/products/97009_120.htm. I was hoping you could give me a quote for everything I need for the conversion and if you know if I could use the Delta housing.
Also I was wondering if you have led bulbs for the XJ tailights.
johnyk440 is offline   Reply With Quote
Old February 16th, 2010, 02:23 PM   #88
johnyk440
johnyk440's Avatar
also would a 50w in 6000k work since the housing is metal and glass
Old February 16th, 2010, 04:47 PM   #89
BooGTS
Boost Withdrawl
BooGTS's Avatar
I can do the 50w bixenon (high and low beam are both xenon) for $110 ($20 more for the bixenon, and $20 for the 50w) and they will work right with your Delta housings. Being e-code, they should be just as good for HID as the ones I sell.
I have LED's for everything in the tail lights (though you wouldnt want to do blinkers unless you wire in resistors)
Old February 16th, 2010, 06:05 PM   #90
johnyk440
johnyk440's Avatar
Awesome thank you. What else do I need, would I need a relay harness or anything else? Also how hard is it to install them, and is there any guides or directions?
Old February 16th, 2010, 07:40 PM   #91
BooGTS
Boost Withdrawl
BooGTS's Avatar
The harness comes with a bi-xenon kit and it has instructions on how it goes together. Some XJ installs have been shown on previous pages of this thread as well. As always, if you have a question, I'm here to answer them too. For the most part, when you get the kit, it is easy to understand, and can only work one way. The longest part of an XJ install is just taking the glass housings out.
Old February 16th, 2010, 08:00 PM   #92
johnyk440
johnyk440's Avatar
ok ill send you a pm
Old February 16th, 2010, 08:12 PM   #93
alix4d
Proud Owner of 0 Jeeps
alix4d's Avatar
yea mine do it but it never bothered me enough to complain because im normally listening to my ipod.
it has been over 3 months and i love the lights! it annoys me to drive anything else at night. hahah
alix4d is offline   Reply With Quote
Old March 6th, 2010, 05:53 PM   #94
AceMon
Could've had a v8
AceMon's Avatar
Well I just installed mine today and WOW! They work like they are factory. Even the connector on them plugs right into the oem one on the car so I didn't have to splice or cut a single wire! Everything BooGTS told me about the kit was 100% true and this kit is really good quality. I got the 5000k one BTW and I have no issues with the radio reception with it. I'll be posting pics soon. THANKS BooGTS!!!
AceMon is offline   Reply With Quote
Old March 6th, 2010, 11:21 PM   #95
AceMon
Could've had a v8
AceMon's Avatar
Here is the before and after...
before
after
Thanks again BooGTS!
Old March 10th, 2010, 06:20 PM   #96
johnyk440
johnyk440's Avatar
I am having problems with my HID kit. IT has been working great for the last couple of weeks since I installed it, but now the drivers side will go out after a couple of minutes. If I turn the lights off then on again they will both work for a about 5 minutes then the driver's side goes out again. I was wondering if Ryan or anyone else would be able to help me me out?
Old March 10th, 2010, 06:45 PM   #97
BooGTS
Boost Withdrawl
BooGTS's Avatar
Sorry you're having an issue. Can you help me remote-diagnose it by swapping the ballasts from one side to the other and see if the problem reverses itself. Obviously if the issue switches sides, its a bad ballast. If not, its a bad bulb or ground likely.
Old March 11th, 2010, 11:06 AM   #98
johnyk440
johnyk440's Avatar
I have the ballasts mounted on pretty well with heavy duty mounting tape, so instead I switched the headlights with the bulbs and everything. I found out that the other side goes out now, same bulb and unit that plugs into the ballast. If you would still like me to switch the ballasts or try something else I can also do that.
Old March 11th, 2010, 03:50 PM   #99
junk90xj
ALLPRO AUTO
junk90xj's Avatar
ryan, pm sent
http://www.apalansing.com/
Old March 17th, 2010, 02:46 PM   #100
tjx54
tjx54's Avatar
how much for the headlight conversions, and a set of the 5000k 55 watt that have the high and low beams for a 99 xj and 2 sets of h3 55w 5000k for 4 700ff hellas
tjx54 is offline   Reply With Quote
Thread Tools
Page generated in 0.45703 seconds with 83 queries
