HID Xenon Headlights - digital slim ballasts locally - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old November 12th, 2009, 08:42 PM   #41
ksejeeper
Money pit
ksejeeper's Avatar
Send a message via Yahoo to ksejeeper
got mine tonight and Installed them in about 45mins. put them on my 2004 F-250. had to modify the head light retaining nut that keeps the light sung against the housing. had to cut 2 of the 8 taps to slip the harness in to it so it would would hold the light on. That was the only problem I ran in to other wise It IS PLUG AND PLAY, AND THEY LOOK COOL.
2012 Can-Am commander 1000 X
2014 Ram 3500 Meg Cab 4x4 6.4 Hemi Blacked out edition.
ksejeeper is offline   Reply With Quote
Old November 12th, 2009, 08:52 PM   #42
BooGTS
Boost Withdrawl
BooGTS's Avatar
The 9007's are a pain, but I never had to cut tabs to get the harness through. Thanks for the feedback though, I'm glad you like them - and that they made it for your trip.
BooGTS is offline   Reply With Quote
Old November 14th, 2009, 03:24 PM   #43
RyeBread
Catch the wave
RyeBread's Avatar
Ryan. Are the H1's the same price? I think I want them for the fogs now.
Are the 35 watt and 55 watt H1's physically the same size?
Old November 14th, 2009, 06:25 PM   #44
BooGTS
Boost Withdrawl
BooGTS's Avatar
Same price. 35 and 55 are the same size external dimensions, only difference with the bulbs is the amount of gas.
On that note - I'm out of 5000K H1's, and didn't order any 55w ones. I'll have the 35w's in two weeks.
Old November 14th, 2009, 07:24 PM   #45
RyeBread
Catch the wave
RyeBread's Avatar
thanks! I have some more research to do on how much of a pita it is to modify the stock housing anyway. Mazda/Ford supposedly have a weird/odd method of installing the bulb, which is one of the reasons why I thought/assumed it was a sealed unit (every, I mean every manual shows replacing the entire assembly - in part probably because the bulbs typically fail only when the lens is cracked)
I'm pretty sure I'll pick up a set of the H1's from you in two weeks. I'll confirm and/or give ya' a call later on it.
Old November 14th, 2009, 10:44 PM   #46
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
I think I might just have to do this to my truck.
*2007 Rubicon
*2006 Duramax
Old November 17th, 2009, 08:57 PM   #47
98ZJ318
RIP 2-15 12:20 AM
98ZJ318's Avatar
pm sent
98ZJ318 is offline   Reply With Quote
Old November 22nd, 2009, 09:39 PM   #48
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Nice kit... quote to 37075 for a 06 TJ sealed beam high/low 5000k and a 94 k5 blazer with seperate high/low in 5000k flavor. Thanks oh and we will do the review.
Old November 24th, 2009, 11:18 PM   #49
EMAXX620
EMAXX620's Avatar
Send a message via AIM to EMAXX620 Send a message via MSN to EMAXX620
im going to try to get up a quick review next week. been to busy to take some pictures lol
I can say its nice to be able to blind some stupid ass slow person and make them speed up to the speed limit :)
EMAXX620 is offline   Reply With Quote
Old November 29th, 2009, 08:42 PM   #50
00xj74
00xj74's Avatar
Ok so I bought 50 watt H3 HIDs for my Hella 500FF's on the bumper of my jeep. First off Ryan is a very stand up guy and offered to answer any questions that I had, which to me mean that he actually cares about his customers. I am very pleased with the light output and quality of the HIDís.
Now for the write up...
1.) I already had the lights off of my bumper, but if you donít just take the 1/2" bolt off that allows the lights to pivot up and down.
2.) Once the light is removed take the lens out of the housing by removing the Phillips head screw, and put the light down on a towel to prevent the counter from scratching the lens.
3.) Now is when the custom "fabrication" starts. Pull off the tab that holds the original H3 bulb in, because it will no longer be needed for the lights. Now carefully put the bulb in the lens and bend the tabs the held the tab on. I donít have any in progress pictures of this step because I was trying to not ruin my lights.
4.) Now that the bulb in the lens a hole can be drilled into the housing to accommodate the extra length of the bulb and to allow the wires to exit the housing. I used a 1" drill bit to drill a hole in the center of the housing. I wanted the grommet to fit very tightly. I forgot to take pictures of this step but it is pretty self explanatory.
5.) This is one of the last steps to installing these lights, mounting the Ballasts. I mounted mine on the radiator with a zip tie and a screw through the cross member, but it really can be mounted anywhere.
6.) The last step is to wire up the lights. I didn't take any pictures of this step, because I just followed the directions on how to wire them.
00xj74 is offline   Reply With Quote
Old December 8th, 2009, 10:11 PM   #51
methodx55
methodx55's Avatar
Send a message via AIM to methodx55
I had a 6000 Watt HID kit installed on my S10 about 2 months ago and just got around to getting pics
These Lights are Awesome!
methodx55 is offline   Reply With Quote
Old December 9th, 2009, 04:04 AM   #52
94transam25th
94transam25th's Avatar
if that guy from the earlier post is still looking for a combination of H7 and H9 im sure we could work something out cuz i only need one of each also
Im guessing ur looking for a gsxr too?
94transam25th is offline   Reply With Quote
Old December 9th, 2009, 08:04 AM   #53
warmpancakes
FNG here came over from Motown Muscle, few guys said you were the one to deal with. Basically I need a kit for a 92 GMC typhoon I made my own harness but i need the globes im looking for a white light output, so I guess the 5k output? I can pick up seeing as I work in rochester hills now is it still the 120?
warmpancakes is offline   Reply With Quote
Old December 9th, 2009, 08:55 AM   #54
BooGTS
Boost Withdrawl
BooGTS's Avatar
That'd be the second Typhoon in a month, and yes, $120 for a low beam xenon high halogen kit, and a pair of glass e-code housings. 5000K would be pure white. I'll PM my contact info.
Old December 20th, 2009, 11:45 PM   #55
bantag
how much to convert a 98 xj over to HID? i have been trying find a way to convert my headlights over....
bantag is offline   Reply With Quote
Old December 22nd, 2009, 09:18 PM   #56
BooGTS
Boost Withdrawl
BooGTS's Avatar
$70 kit
$10 harness
$50 headlight housings
So $130. $150 if you want both low and high beam Xenon.
Old December 23rd, 2009, 08:43 AM   #57
molds02
Pwned
molds02's Avatar
how much for everything i need for a 1999 gmc yukon
molds02 is offline   Reply With Quote
Old December 23rd, 2009, 10:56 AM   #58
BooGTS
Boost Withdrawl
BooGTS's Avatar
$80 (all GM trucks need a relay harness). I got your PM as well, just haven't had the energy to compose an intelligent response
Old December 23rd, 2009, 11:10 AM   #59
hondadirtracer
Skymaster
hondadirtracer's Avatar
Did you ever figure out what the problem was with MUDBOG101 and the interference on the radio when the lights are turned on?
hondadirtracer is offline   Reply With Quote
Old December 23rd, 2009, 11:54 AM   #60
BooGTS
Boost Withdrawl
BooGTS's Avatar
No, he was the only one to have the issue and we never figured out why. Usually its due to a bad antenna or ground. You get a very slight bit of interference on weak stations with any install, but nothing of note.
Thread Tools
Page generated in 0.62662 seconds with 83 queries
