Auto trans ? C4/C6/AOD - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 15th, 2009, 10:34 AM   #1
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Question Auto trans ? C4/C6/AOD
Looking for opinions on what trans to run. mild 351 for now in a wrangler.
C6- parasitic loss?
C4- leaning this way as it can be made real short but worried about future power upgrades?
AOD- strength?
So what would the last two hold up to power wise being built? I would go with the C6 just don't want to lose any of the whopping 250hp
Old October 15th, 2009, 11:59 AM   #2
camccardell
tiger blood
camccardell's Avatar
e4od if you got money
c4HD should be fine, had one in my ranger on a 351w, no OD though
Old October 15th, 2009, 12:22 PM   #3
BOGDOG
BOGDOG's Avatar
The C4 in my 73 Bronco needs to be redone but it was in the truck when I bought it 15 years ago did some time as a summer DD. I have been running a 300HP 351W thru it. It still works but could use some freshening up. A buddy used to toast a C4 every 3 months in a 69 Stang with a mild 302 but I would attribute that to poor trans builder/driving style.
Old October 15th, 2009, 12:26 PM   #4
Icebreaker88
Icebreaker88's Avatar
If you dont need OD go with the C4. They can be built cheap to handle whatever you want to put through it.
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old October 15th, 2009, 12:55 PM   #5
95Geo says to run a 4L60e...
Old October 15th, 2009, 12:57 PM   #6
Jeepaholic
Jeepaholic's Avatar
Thanks guys, looks like I get to be like you Hag-gar and run a FMVB as the shorty C4-Atlas requires one as it removes the governor
Old October 15th, 2009, 01:01 PM   #7
s.hembree
s.hembree's Avatar
If you don't mind a little extra cost the 4r70w is a great option. Programmable and extremley strong...
Old October 15th, 2009, 09:35 PM   #8
Offroadexpy
Rockin' the Stocker'
Offroadexpy's Avatar
The C6 is the strongest, by far, nothing modern can touch it, but it sucks 55hp right off the top.
The C4, weak in stock form, but can be built stout as a C6.
AOD- Junk.
Offroadexpy is offline   Reply With Quote
Old October 15th, 2009, 09:47 PM   #9
wingman573
Here and gone
wingman573's Avatar
I would go with a C6. E4OD would be my next option if you want overdrive, but they aren't that strong and usually cost quite a bit to repair
wingman573 is offline   Reply With Quote
Old October 15th, 2009, 09:50 PM   #10
I've been haggling over a similar issue, 351W and I have a c6 for it now but have a good e4od available but would need to swap out the tail shaft (which I have).
Old October 15th, 2009, 11:08 PM   #11
sandguy356
bronco built for fun
sandguy356's Avatar
A c-6 with good parts is darn near unbreakable, the newer c-4 stuff is really good also, and almost as strong, but lighter weight. Find somebody that knows what they are doing with either one, and its all over.
sandguy356 is offline   Reply With Quote
Old October 16th, 2009, 11:00 AM   #12
Pipeliner_86
Pipeliner_86's Avatar
What about a C4 built, with a gear vendors overdrive unit behind it?
Pipeliner_86 is offline   Reply With Quote
Page generated in 0.28097 seconds with 59 queries
