Project "ball dropper" - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 15th, 2009, 07:15 AM   #1
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Default Project "ball dropper"
For about a year I have been gathering parts etc.. to re-start this project =
Yup, rig build. - Great Lakes 4x4. The largest offroad forum in the Midwest
I hope to finish it this time .
Anyways, Scott was a good guy to deal with and I hope he and everyone else here will help me keep from screwing this up. I am working on pictures and know I need to get them to really get good input.
I currently have:
Mounted the 5.3, 4L60E, NP231 in the frame.
Installed 35" BFG M/T's.
Removed the tub.
EDIT: Some of the details etc..
rear axle =
79ish 9", 31 spline, 65.5" wide, 5/5.5 bp 5.13 gears, full spool (going to a detroit some day Hopefully))
CJ-7 front rotors and GM S-10 F. calipers
http://www.greatlakes4x4.com/showthr...874&highlight=
front axle =
HP 44, drivers drop, all new bearings and seals, Yukon shafts, Longfield joints, 5.13 gears, welded carrier, new calipers, aluminum tierod, 5/5.5 outters, brand new Warn lockouts.
http://www.greatlakes4x4.com/showthr...028&highlight=
__________
Biggest problems to work through right now are suspension questions. The rear 4-link needs to be moved forward aprox. 4-5" to allow an under frame fuel tank. I can not have the tank in the tub (to much other stuff I need to carry in there).
Next step = move rear axle forward.
RIP FULLSIZE4LIFE
Last edited by SHARPMACHINE; May 31st, 2016 at 11:44 AM. Reason: trying to add photobucket pictures
Old October 15th, 2009, 07:36 AM   #2
SHARPMACHINE
F-U-CANCER!!!
Another question? How do I attach a 4-link calculator to the thread?
CURRENT REAR =
SHRINK 4" REAR =
RIP FULLSIZE4LIFE
Old October 15th, 2009, 08:50 AM   #3
VonDirt
VonDirt's Avatar
have you checked out some different tank shapes or configs ? maybe splitting the difference and moving it up just enough to clear - eg. a partial hump in the tub so you still have space for your junk
just thinking . . . . it looks good the way it sits
VonDirt is offline   Reply With Quote
Old October 15th, 2009, 11:58 AM   #4
Sometimes it's the easy things that get overlooked
Thread here:
http://www.pirate4x4.com/forum/showt...k+modification
Fookie, just saw that you posted in that Pirate thread I'll go away now
Old October 15th, 2009, 12:52 PM   #5
95geo
newbie
95geo's Avatar
Make the calculator the current window with what you want captured visible on the screen, press Alt+Print Scrn. Open up MS Paint and press Ctrl+V. Save as a .jpg or your favorite suffix and then attach as an image here.
Old October 15th, 2009, 05:29 PM   #6
SHARPMACHINE
F-U-CANCER!!!
Well, I tried doing it above, but the image sucks??? I will try againg tomorow.
Also, I know about modifying the fuel skid and tank. I will have to do that as well. Right now the rear is stretched ~ 7" and I hope to keep it stretched ~ 3"????
Thanks for the comments.
RIP FULLSIZE4LIFE
Old October 15th, 2009, 05:52 PM   #7
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
if you need a custom fuel cell built to clear everything let me know. i am a fully certified pipe welder and can weld aluminum, stainless steel, or black steel.
Old October 16th, 2009, 06:49 AM   #8
SHARPMACHINE
F-U-CANCER!!!
I "think" this is better? I have shown where it is now and aprox. where it would be if I just shortened all of the links 4".
Hope to cut them down this weekend and would greatly appreciate any input I could get before hand.
Thanks again
RIP FULLSIZE4LIFE
Old October 16th, 2009, 08:58 AM   #9
95geo
newbie
95geo's Avatar
I'd try to get a couple more inches of vertical frame seperation by moving the upper link frame mounts up if it's possible. $0.02
Old October 16th, 2009, 09:38 AM   #10
SHARPMACHINE
F-U-CANCER!!!
Thanks!!!! It was in the lowest hole so this is ~ where it would be if I went to the top hole. Thanks ALOT for your time and input .
lower portion =
RIP FULLSIZE4LIFE
Old October 19th, 2009, 11:06 AM   #11
OCA#1
Redneck at Heart
OCA#1's Avatar
Look a big stupid mud jeep.=] just kiddin keep up the good work.
OCA#1 is offline   Reply With Quote
Old October 19th, 2009, 03:31 PM   #12
pistol pete
I do vinyl stickers
pistol pete's Avatar
i had the same problem with my jeep. i cut a hole in my floor and put the tank half way through, the pig dosent even come close to hitting it, i built a small box around it to enclose it. the back seat still fits in its stock location.and i could still put stuff behind the seat.
pistol pete is offline   Reply With Quote
Old October 19th, 2009, 03:44 PM   #13
pistol pete
I do vinyl stickers
Old October 19th, 2009, 03:47 PM   #14
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Originally Posted by pistol pete View Post
you might need a bigger shackle
I'm the man in White.
Old October 19th, 2009, 03:49 PM   #15
pistol pete
I do vinyl stickers
Old October 20th, 2009, 10:16 AM   #16
SHARPMACHINE
F-U-CANCER!!!
Chopped 4" from each of the rear links, re-tapped etc.. Now the tank and skid plate will fit with some "minor" modification. I was unfortunately not willing to cut the inside of the tub and would rather work around it.
Next = Try to allign it a little and start working on driveshafts, exhaust, fuel & brake lines etc.... Also need to do bump stops, spring retainers and limiting straps. Might only need limiting straps in the front?
Will try to get pictures soon. Exhaust is going to be tight. Not alot of spare time to work on it though.
RIP FULLSIZE4LIFE
Old October 30th, 2009, 08:18 AM   #17
Strangler
Strangler's Avatar
Fuel tanks are overrated. I owned that jeep for a couple years and never needed one. Post pics of your changes!
Old October 30th, 2009, 11:08 AM   #18
OCA#1
Redneck at Heart
OCA#1's Avatar
Are you done yet?
Old October 30th, 2009, 11:15 AM   #19
Avnxtek
Avnxtek's Avatar
Any bets on when the Part-out starts
Avnxtek is offline   Reply With Quote
Old October 30th, 2009, 01:58 PM   #20
OCA#1
Redneck at Heart
OCA#1's Avatar
He will part it when hes gotta the next great idea for a rig.
Page generated in 2.14676 seconds with 84 queries
