Creaking or pops while accelerating - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 14th, 2009, 10:57 PM   #1
The Nuge
Season's Here
The Nuge's Avatar
Send a message via AIM to The Nuge
Default Creaking or pops while accelerating
I have a 94 F150 and just had the oil pan replaced. After I got it back I noticed that when I accelerate, there is a creaking/ 3-4 pops while increasing in pitch as the truck accelerates through the very beginning of first gear. Sometimes there is a creaking right before shifting into second. Once it hits second, there may be very little noise if any. And so on is fine. If I accelerate harder/faster, the noise is louder. Sometimes when accelerating and turning at the same time its easily noticeable as well. If I brake torque it a little, it will make the 3 pops. If I try to do it again in the same spot, it will not make the sound. If I roll the truck foward a foot and brake torque it a little again it will then make the sound again. Please let me know what you think.
The Nuge is offline   Reply With Quote
Old October 15th, 2009, 06:02 AM   #2
Yota Bill
make sure all bolts are tight, especially the motor mounts
Old October 15th, 2009, 10:04 AM   #3
7.3X
Fullsize support vehicle
7.3X's Avatar
Do you feel anything in the floor/trans tunnel/firewall/pedal assembly/ when the noise occurs?
7.3X is offline   Reply With Quote
Old October 15th, 2009, 10:22 AM   #4
94rangeron35s
bought a Jeep
94rangeron35s's Avatar
kinda sounds like it could be a bad U joint. will it make the same noise if you go in reverse from a stop or does it clunk at all when shifting from drive to reverse?
Old October 15th, 2009, 01:05 PM   #5
The Nuge
Season's Here
The Nuge's Avatar
I can slightly feel it in the floor boards. If I listen while hunched down by the front tire, and someone brake torques it to make the sound( 3 consistent pops), it sounds like its coming from the front half of the vehicle, maybe even around the front axle area. Could not put a direct spot on it.
The tires were about 22 psi and I put them at 45, max is 50. The sound has decreased by a pop or two I noticed. I have not driven it much but I will listen again to see if it is consistently quieter. It seemed a good deal quieter.
Not when shifting at all, and I believe no noise in reverse at all but will double check.
Keep em coming guys
Thanks guys
Old October 15th, 2009, 02:50 PM   #6
7.3X
7.3X's Avatar
Hot or cold does it matter and does it do it every time you go to accelerate, hard acceleration or light? Weight or no weight? Lastly can you at least isolate it to a specific corner or side. I have seen bad caliper brackets rattle and calipers that are sticking lightly grab and let go at slow speeds where it would be noticed. 4x4 or 4x2 and what do the front end bushings look like? Good luck, Ron
Old October 15th, 2009, 03:13 PM   #7
The Nuge
Season's Here
The Nuge's Avatar
Hot or cold doesnt matter. It does it everytime I accelerate hard, and most of the time when I accelerate VERY soft. No weight. I would have to say drivers side but easily heard from passenger seat through floor. 4x2 and 4x4 is when it does it. Bushings look decent.
Old October 15th, 2009, 03:58 PM   #8
7.3X
7.3X's Avatar
Sounds stupid but check the ball joints. Just a shot.
Page generated in 0.22237 seconds with 47 queries
