help with my damn dodge!!!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 13th, 2009, 08:45 PM   #1
sethengelhardt
sethengelhardt's Avatar
Default help with my damn dodge!!!!
all right here goes, I have a 2000 ram 2500 with a 5.9 in. It started missing when it get wet. I checked for codes and its thowing a loss of cam/crank signal. I replaced both sensors and it's still doing the same thing. I replaced the coil, still there. Got a wire diagrahm and checked all grounds, still does it. Just for fun I put all new injectors and cleaned the fuel rail, still runs like shit, but i get better mileage.
One friend says change the computer. Another says it's a bushing at the bottom of the distributer.
Here is the deal. It's a 2000 truck and I don't have the cash to just keep swapping parts till I find it.
CAN ANYONE HELP? Feel free to post a replay, but please pm it to me also.
sethengelhardt is offline   Reply With Quote
Old October 20th, 2009, 08:50 PM   #2
gmotox
gmotox's Avatar
Check the coil power plug, I changed computer and all kind of shit, it turned out to be the power wire connection had a bad connection.
Old October 21st, 2009, 12:11 AM   #3
Flat_Black
The Dodge Guy
Flat_Black's Avatar
might be a bad pick up coil. (under dist. cap and rotor 2 screws on the out side of the dist holding it in place)
Old October 27th, 2009, 03:58 PM   #4
sethengelhardt
ran a new wire from computer to the coil and new power wire on the coil still there. Ordered a new computer, I hope thats it. If not I will go flat blacks way and probably just replace the whole distrib. as I tried to change the cap and both the screw that hold the cap on have rust welded themselves on and I am pretty sure they will break if I force them off, thanks to both of you for the help.
Old October 27th, 2009, 05:20 PM   #5
dodgeboy
redneck truck club
dodgeboy's Avatar
i would get that cap off of there and replace it! with a new rotor before buyen a computer! theres one bolt holding the dist. down and chryslers only go in 2 ways just make some marks.they dont have a gear or the bottem! its like a flat head screwdriver. the computer controls the timing so just get it close to where it was and you will be fine. caps like 15$ and the rotors like 8$ alot cheeper then a computer!!!
dodgeboy is offline   Reply With Quote
Old November 1st, 2009, 06:46 PM   #6
sethengelhardt
put the computer in and it didn't fix anything. going to fight with the distributer tomorrow. getting a new cam sensor, cap, and rotor for it. Already put new plugs and wires on it. If still tmissing I will have to buy the dist. and from there I will just give up and go to the dealer.
Old November 1st, 2009, 06:48 PM   #7
Flat_Black
The Dodge Guy
Flat_Black's Avatar
i would bet money its the pick up coil
Old November 13th, 2009, 05:16 PM   #8
sethengelhardt
flat black owes me money then, replaced the pick up coil, distributor, and crank sensor. did not fix anything.now its clicking and on the old crank sensor it looks like the flex plate may have been rubbing on it. Maybe a cracked flex plate? I don't know this is going to send me to the poor house chaseing parts tho. I gues s I have to drop the trans next, maybe a new motor. Is this truck worth all this?
Old November 13th, 2009, 05:24 PM   #9
Pokerob
hug life
Pokerob's Avatar
why would you not pay the 50$ or whatever to get it diagnosed at a reputable shop?
then fix it yourself?
Old November 13th, 2009, 07:34 PM   #10
Freak
Wheelin the HD
Freak's Avatar
unplug your 02's sounds similar to what I was dealing with on my 95, and you've done most of the stuff I had, turned out my o2 sensor was bad, made it miss burn excessive fuel and try and stall when I was driving it.
Old November 14th, 2009, 07:49 AM   #11
sethengelhardt
pokerrob, it has been at several shops and I was trying to avoid throwing parts at it, look what happened anyway. The guy who is working on it know is a trouble shooter for chrysler. This has stumped alot of people including a dealer. I have not been doing all this myself. The dealer said it was the computer and replaced that and the wire harness, didn't work. I did the fuel injectors, fuel rail, and coil. And so on. It has been to 2 shops, a dealer, and now my friend. The dealer was just too much $. The Midas it went to couldn't fix anything and said it was over them. Then went to the dealer, then the shop in walled lake. Everybody has a guess and want to throw parts at it. The problem is That still does not fix it and they still want me to pay for parts and labor.
And freak, thanks for the advice, but already replaced both 02 sensors at the shop in walled lake and they said they are reading correct and thats no the issue. My friend that trouble shoots for chrysler thinks its a cracked pressure plate and it is hitting the crank position sensor throwing the code. problem is We have to r&r the trans to find out, could not see anything after loosing the inspection plate.
Old December 11th, 2009, 07:27 AM   #12
sonic
sonic's Avatar
Im assuming over the course of all this the plugs wires and cap and rotor were all changed. Also its is somwhat common to get bad PCMs and sensors out of the box. You may want to contact chrysler and see what they can due to help you with repairs that were performed at the dealer if I read that right.
sonic is offline   Reply With Quote
Page generated in 0.26539 seconds with 59 queries
