delete please - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 13th, 2009, 06:26 PM   #1
osnapchuckie
learn after breaking...
osnapchuckie's Avatar
Default delete please
I have a 94 Explorer 4x4 that has the A4ld stock standard with the 4.0 Liter.
I want to put a manual 5 speed in it. I have never done anything like this and would like any information and advice that could help.
Is this an easy task?? and has any one done this?
osnapchuckie is offline   Reply With Quote
Old October 13th, 2009, 06:44 PM   #2
You need the clutch pedal assm from a manual explorer/ranger. Either just the pedal or the whole brake/clutch pedal assm. You need the slave cyl and line.
The m5ord is the same length as the A4LD so no driveshaft or crossmember modifications needed.
You can pull up the carpet and theres an access panel you can remove to put the shifter through the floor.
Then you need to either wire in a NSS or just jump two wires in the loom of the auto NSS to allow the starter to crank.
Page generated in 0.12360 seconds with 29 queries
