1996 Silverado 5.7L Vortec- Dogging it after start-up - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 13th, 2009, 04:15 PM   #1
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Default 1996 Silverado 5.7L Vortec- Dogging it after start-up
So everyonce in a while the after my truck has been sitting for a while, it's cooled down to surrounding air temp, When i start it, it starts fine, 1 second to turn over, and it runs just fine nothing wrong. But sometimes when i go to take off in drive, doesn't do it in reverse (prolly cause I don't give it much gas in reverse lol), It seems like its boggin down, there's fuel and it doesn't seem like it's about to stall or anything, it's just there's not as much forward movement as there should be.
I was thinking that it might be the transmission, if it was the motor shouldn't it be doing something else anyother time?
anyother thoughts?
Thanks In Advance
Old October 13th, 2009, 09:07 PM   #2
Gr8wht2000GMC
Gr8wht2000GMC's Avatar
your mass air flow sensor may be f'ed. if the problem seems to last like 30 seconds or so then clear up, get a new one [MAF}
Gr8wht2000GMC is offline   Reply With Quote
Old October 14th, 2009, 07:00 AM   #3
IFS SUCKS
I like trees
IFS SUCKS's Avatar
Or try cleaning it first.
IFS SUCKS is offline   Reply With Quote
Old October 14th, 2009, 01:31 PM   #4
wave_crusher
I'll Direc your TV
May sound retarted but oh well lol....
how do I clean it?
Old October 14th, 2009, 02:19 PM   #5
ben
nmu trailcats
ben's Avatar
use maf sensor cleaner and a toothbrush, the soft brissles wont put scratches into the aluminum
ben is offline   Reply With Quote
Old October 14th, 2009, 03:15 PM   #6
Gr8wht2000GMC
but do NOT TOUCH the three wires on the inside with ANYTHING
Old October 15th, 2009, 10:22 AM   #7
wave_crusher
I'll Direc your TV
ok, i'll give it a clean
And it just did it again last night, this was the worst time so far though.
It was sitting for about 6 hours, it was about 35 degrees out, i started it up and it started fine and everything but when i went to take off it wasn't drivng forward like it should. I was pushing the gas, but the motor wasnt revving and it was like it just wasn't getting the right amount of gas for how much i had the pedal pushed in
It wasn't spitting or sputtering, it was runnig fine but it just wan't revving or moving like it should have been
Old October 15th, 2009, 05:22 PM   #8
blownexploder94
Todd
blownexploder94's Avatar
fuel filter? does it have any codes? have a real scanner thrown on it, make sure both coolant temp sensors are working properly, and a 98 do something similar, one showed like 50 degrees and the other one showed like -39 degrees but it straightened up when it got good and warm, but was still over fueling.
Old October 15th, 2009, 05:24 PM   #9
blownexploder94
Todd
is it actually in 1st gear, or trying to take off in 2nd
Old October 15th, 2009, 06:31 PM   #10
wave_crusher
I'll Direc your TV
it's in overdrive, but other than that I don't know if it's actually in 1st gear, it does make sense though.....
No codes, hasn't thrown the check engine light since i've had it
it doesn't need to get up to op temp, just for the first few seconds of acceleration, is when it does it
Old October 15th, 2009, 08:36 PM   #11
Disturban
Disturban's Avatar
Replace fuel filter and then check fuel pressure. My wifes Bravada started doing that right before the fuel pump took a shit...replaced pump and filter and it runs like a champ!
Old October 16th, 2009, 11:26 AM   #12
IFS SUCKS
I like trees
IFS SUCKS's Avatar
We clean them all the time with a q-tip and carb cleaner.
Page generated in 0.27868 seconds with 59 queries
