GMC Yukon, noise while turning. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 13th, 2009, 08:54 AM   #1
clarkstoncracker
lol
clarkstoncracker's Avatar
Default GMC Yukon, noise while turning.
4wd of course.
Whenever I turn left I have what feels to be a grinding noise from the front left. It doesn't ever make the noise while going straight. If I turn really sharp going really fast the noise is very very bad.
My question is, CV or Wheel Bearing?
If its the CV, how much of a PITA are they to swap?
Old October 13th, 2009, 09:13 AM   #2
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
CVs are not that hard to swap.
If it's a wheel bearing, you should be hearing the noise in 2WD too, and should be louder when you turn to the right and more weight transfers to that bearing.
By you turning very sharply to the left and the noise is getting worse, my money would be on the CV. If it's a wheel bearing, the noise should not be as pronounced when turning left.
Old October 13th, 2009, 09:19 AM   #3
clarkstoncracker
lol
Awesome. thanks
Wonder if I should just swap out both..
Old October 13th, 2009, 09:23 AM   #4
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Depends on how long you plan on keeping it.
Old October 13th, 2009, 10:06 AM   #5
DuffMan
Your Message Here
DuffMan's Avatar
What's your speed during said turn?
Old October 13th, 2009, 12:08 PM   #6
GreaseMonkey
Pew pew!
Awesome. thanks
What year and how many miles? If it's over 100,000, I'd just do the wheel bearing too. You can either get the CV out through the knuckle, or you may have to swing the entire knuckle out of the way.
Old October 13th, 2009, 04:10 PM   #7
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Pretty easy way to check both
Check the cv by grabbing a hold of it and wiggling it around, it should move in and out of the hub, that's why it's called a constant velocity shaft lol, but there shouldn't be any other play in it at all, there shouldn't be any up and down or front to back movement in it
Check the wheel bearing by jacking up the front of the yukon, grab a hold of the front and back of the tire and try to wiggle it, if there's any movement in it then it's the wheel bearing, also if it's bad just turn the wheel, if there's excessive noise that doesn't sound like a brake rotor, again, it's the wheel bearing
could be both too
Old October 13th, 2009, 04:12 PM   #8
wave_crusher
I'll Direc your TV
to get the cv out all you have to do is just unbolt it from the hub (big ass locking nut) unbolt it from the half-shaft ( i think 6 bolts?), and either take off your sway bar link or the shock, with both those in place there isn't room for the cv to pull out or for the new one to go back in. The shock is usually easier, since the you have to reach your fingers through a small opening to get the sway bar link back on
Old October 13th, 2009, 05:58 PM   #9
howell_jeep
Last Free Man
howell_jeep's Avatar
I would just soak it up in a RED food dye for a day or so and they should be as good as new! :)
I SHOOT RAW!
Exercise your rights! Open Carry!
howell_jeep is offline   Reply With Quote
Page generated in 0.28617 seconds with 50 queries
