out door wood boiler - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 12th, 2009, 08:48 PM   #1
roger
roger's Avatar
Send a message via AIM to roger Send a message via Yahoo to roger
Default out door wood boiler
anyone ever build one. do you have a right up, how do you like it
roger is offline   Reply With Quote
Old October 13th, 2009, 12:33 AM   #2
Mclovin
"The Situation"
Mclovin's Avatar
my cousin has built tons of them .. built a set up for his house and my uncles house.. and builds them to sell .. if you wana drive to custer kentucky to pick it up im sure he's build you a set up
he heats his house garage hot water and pool with it..
Ill see if i can get ahold of him and see if he has any more info..
Old October 13th, 2009, 11:35 AM   #3
roger
roger's Avatar
thanks
Old November 7th, 2009, 05:16 AM   #4
redleg
Built mine using a 400 gal., electrical transformer for the tank. Firebox is 30"diax 1/2" underground compressed gasline stub. Chimney stack- 1/2"x9" pipe. Handle is made from a leaf spring for tension on the door. All from the scrap yard. Got 300 feet of Pex off ebay for $150 shipped. Circulating pump $80-$90, aquastat, same price. It's great if you have wood access, firewood has gone up alot. I burn alot of trash and scrap in it too. I built a shed around it for now. Still plan to frame it up and insulate it with foam. I've seen guys have foam done for $400 or so.
redleg is offline   Reply With Quote
Old November 7th, 2009, 05:44 AM   #5
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
there is another member on here that builds them too - he'll post soon - I'll try to remember his username too.
@clarkstoncracker
Old November 7th, 2009, 06:10 AM   #6
Boomie69
It's an addiction
Boomie69's Avatar
PM mpruitt4x4. He builds them as well. I don't think he has a write up but he may be able to get you more information.
Boomie69 is offline   Reply With Quote
Old November 7th, 2009, 07:40 AM   #7
kkodet
kkodet's Avatar
Weigh out whether you want an indoor or outdoor one first. I thought of both, but went with an indoor wood boiler. I use much less wood than the outside ones, and I don't have to get all dressed up to go out and fill it. Using hardwoood, I can usually fill it twice a day with about 8 small logs.
Old November 16th, 2009, 09:24 PM   #8
roger
roger's Avatar
yea i want an out door one, anyone else
Old November 16th, 2009, 09:24 PM   #9
roger
roger's Avatar
you have any pic
Old November 16th, 2009, 10:27 PM   #10
Yota Bill
I'm also considering building one, to heat the house and the barn...was thinking of building a waste oil furnace to heat the shop, but the cost of the stove pipe makes it not really worth building, since I was interested in it due it costing me nothing to build it...an outside wood burner would solve that issue, along with adding a way to heat the house at the same time.
Old November 16th, 2009, 10:27 PM   #11
Mclovin
"The Situation"
Mclovin's Avatar
My cousins is built using an old propane tank.. has a hole in the door for air to come in with a valve on the intake tube.. the valve is thermostatically controlled based on water temp i believe.. it closes so you don't burn through all your wood so fast when the heat isn't needed.. the door i believe is cut from 1/2" steel. uses 110v circulatory pumps. the whole set up heats very well. He also covered the entire thing in what look like great stuff expanding foam but it comes in like R 134a cylinders and mixes in the hose.. im not sure what he used for hose but its also covered in the foam..
Old November 17th, 2009, 02:16 AM   #12
jeepguy74
jeepguy74's Avatar
there is a pl,ace in hersey MI, that selles just the wood burning tank all the way up to full units at a fair price also sells parts.... found their ad in the misc ads in the back of the free auto/rv it was on the first page of the misc section
Old November 19th, 2009, 06:49 PM   #13
roger
roger's Avatar
hey can you get me a name please
Old November 26th, 2009, 06:04 AM   #14
jeepguy74
jeepguy74's Avatar
timberwolfstoves.com
Old November 27th, 2009, 12:45 PM   #15
dirty addiction
dirty addiction's Avatar
i have an outdoor wood boiler i'v been burning for 4 seasons with it now saves you alot of money in the long run but it is alot of maintence collecting wood all season for it but it is well worth it. it has well paid for it self already i put wood in it twice a day nice part with the outside boiler is you can burn any type of wood. good luck with your project.
dirty addiction is offline   Reply With Quote
Old November 28th, 2009, 12:48 PM   #16
roger
roger's Avatar
did you build yours or buy one
Old December 1st, 2009, 10:39 AM   #17
forfun
forfun's Avatar
i bought one a woodmaster great stove heavy duty ,i like the fact you can burn any thing in it,i run mine all summer too heating just water thats when i burn crap wood,if i spent half the money i payed for mine on an indoor stove,"aka" really nice stove i would use half the wood but i could not heat my water in the summer,and my insurance would be higher,if your burning propane a 5000$ stove wood pay for it self fast and you will get a warranty for 10 years. i figure if i can't fit it after 10 years it had aready paided for it self many times over
forfun is offline   Reply With Quote
Old December 1st, 2009, 10:50 AM   #18
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
roger i may have two large tanks that i was going to use to build one i could get you. i was going to put one inside the other. from my quick mathmatics its was going to be just about right with the amount of water needed.
Page generated in 0.43772 seconds with 77 queries
